transit immobiliser problem
Postby guitarmart321 » Thu May 03, 2007 5:41 pm
Hi,
I hope somebody out there can help before I drive me transit over a cliff !!!
Its driving me barmy.
Started about a week ago. Stopped in the morning to pick up a news paper and wouldnt start. The dash lights all work and radio works but nothing!! I noticed the led red light on the consul started flashing fast when normally it goes out when it starts. After 10 minutes it started ok. This keeps happening, sometimes I can be trying it for 2 hours plus. Took it to local Ford garage who said we needed new keys. Still didnt solve problem so took it back to Fords who said it must be the tranceiver. Had new one fitted and no different !!!
I have absolutely no mechanical knowledge whatsoever about this sort of thing, can anyone help.
the van is W reg, year 2000, 2.5 diesel.
Martin
:roll:
guitarmart321
Postby V184 » Thu May 03, 2007 6:48 pm
rim module on the back of the fuel pump ? battery leads ?
V184
Postby OxtonyxO » Thu May 03, 2007 8:15 pm
you need to read the code thats flashing at you
OxtonyxO
Postby guitarmart321 » Thu May 03, 2007 8:49 pm
"you need to read the code thats flashing at you"
Hi,
thanks for your reply, it might sound a bit stupid but what code am I supposed to be looking at ?
Martin :shock:
guitarmart321
Postby OxtonyxO » Thu May 03, 2007 8:51 pm
the way the light flashes
slow and fast , like morse code
OxtonyxO
Postby guitarmart321 » Thu May 03, 2007 9:02 pm
OxtonyxO wrote:the way the light flashes
When I go to start it the red led light just flashes at one speed fast. This is when its not going to start.
guitarmart321
Postby OxtonyxO » Thu May 03, 2007 9:03 pm
it will flash fast when tring to start they when you release the key it should slow down
OxtonyxO
Postby OxtonyxO » Thu May 03, 2007 9:05 pm
there is a few posts on this search for PATS
OxtonyxO
Postby guitarmart321 » Thu May 03, 2007 9:19 pm
OxtonyxO wrote:it will flash fast when tring to start they when you release the key it should slow down
when I turn key to start the light stays alight for a while about 3 seconds then goes out the van starts. When it dosent start the light stays on
for about 3 seconds then starts flashing fast the van will now not start.
Just tried it and started up 4 times in a row!!!!
But if i drove it around the block and then stopped it , it wouldnt start.
thanks :lol:
guitarmart321
Postby gemini » Thu May 03, 2007 9:25 pm
V184 wrote:rim module on the back of the fuel pump ?
i'm thinking this :wink:
gemini
Postby OxtonyxO » Thu May 03, 2007 9:25 pm
have you had all the keys programed to the pats
ie the red and black keys
have you got more than one key to try?
OxtonyxO
Postby OxtonyxO » Thu May 03, 2007 9:27 pm
the rim gives a fault code as my van did when the di was removed
OxtonyxO
Postby guitarmart321 » Thu May 03, 2007 9:33 pm
OxtonyxO wrote:have you had all the keys programed to the pats
Had new keys programmed at Fords cost £188 and no difference !!!
One red key and two black keys with red dots, tried them all.
I think it seems to do it more when just been used. When left over night it starts every time in the mornings. :idea:
thanks
guitarmart321
Postby OxtonyxO » Thu May 03, 2007 9:37 pm
this is from another thread
Hi,
Got the exact same problem.
What code are you getting from led light (if you leave ignition on with led flashing away, a minute or so later it will flash out a code ie it will flash once followed by a short burst of three for example) mine flashed a code of 13. one flash followed by three. It would appear that the key if dodgy.
I've tried to get advice on bypassing but there is a lot of conflicting theories. So on that note got new keys and will find out if it worked on Friday.Will keep you posted.
did you wait the minute or so for the code?
OxtonyxO
Postby djswampy » Thu May 03, 2007 11:42 pm
Daft suggestion. Probably got nothing to do with this. But have you checked the battery and starter motor connections? Thats the main feed/earth, and the control one. Are they Clean and tight? I don't know much about the immobilser systems and flashing lights but it wouldn't hurt to check them over.
djswampy
