Rustproofing a Mk 7 - any special requests?
Postby RacinRob » Tue Sep 06, 2011 7:24 pm
I'm just about to invest in some rustproofing chemicals and give the transit a good blasting.
New compressor is sitting ready to go.
Not 100% sure on taking the waxoyl or dinatrol route.
Planning to blast the chassis members with the wax compound along with inner arches, sills etc.
Question being - what areas cause the most corrosion problems meaning extra attention would be required?
Cheers
Rob
RacinRob
Re: Rustproofing a Mk 7 - any special requests?
Postby whitemice » Tue Sep 06, 2011 7:53 pm
Have a look at Bilt Hamber products r50 and ub waxes. 5l @£40
Front cross members, chassis rails, arches, floor and spring hangers are important but the whole van ie. pillars, doors the lot need doing if it's a keeper.
https://www.youtube.com/watch?v=jIaGWURONRU
'' VOTE Kim Jong Unwell.
Mike writ '' a vote for lABOUR is a vote for islam and a conservative vote is a vote for islam and a vote for liberal is a vote for islam. ''
DBVM ''a vote for UKIP is a vote for islam''
whitemice
Location: normalised heavily chemtrailed cretinous individual just like you
Postby RacinRob » Tue Sep 06, 2011 8:55 pm
That's a quality site - some good products there.
RacinRob
Postby jumbo camper » Tue Sep 06, 2011 9:47 pm
take the lining off the inside in the rear so you can do over the rear arches and seems down to the floor level and also down the rear pillars and rear doors :D
jumbo camper
Postby whitemice » Tue Sep 06, 2011 10:53 pm
RacinRob wrote:That's a quality site - some good products there.
Here's the result of degreasing and overnight in a couple of jamjars, one for each set, and a sprinkle of Bilt Hamber deoxC rust product crystals in water solution on the 26 year old rear wheel nuts, don't put lids on tight as it bubbles, been using this stuff for years and it's brahma like their other products.
I use Bilt Hamber hydrate 80 primer brushed on metal body panels and chassis to neutralise and convert rusty bits and i just use synthetic diamond white brushed straight over that on the amby or wax underneath, after about 5-7 years sat outside a bit of bubbling occurs at some original spots on bodywork but if i do those bits when it happens the areas are not any worse than original and this 26 year old mk2 vehicle is outside 24/7.
You should see things like disc's etc. after a few days in a bucket of deoxC. i know people who put whole doors in solutions of the stuff.
whitemice
Postby RacinRob » Fri Sep 30, 2011 7:55 pm
First thing was to give the underside a good clean:-
After that a good few coats of Bilt Hambers finest:-
Started filling all the internal cavities etc with the wax gunge - it's getting there:-
RacinRob
Postby nscvr6 » Fri Sep 30, 2011 8:52 pm
hi there
maybe a bit cheeky but how much did the rust proofing kit cost ya ?
looks a top job by the way
nick
nscvr6
Postby RacinRob » Fri Sep 30, 2011 9:20 pm
I bought a 5 litre of the underbody black stuff and a 5 litre tin of injection wax - all in it was about £80.
The gun to spray it all was approx £50 from fleabay.
The gun included an extension hose with a right angle fitting on the end that was superb with hardly any overspray
RacinRob
Postby Damien89 » Wed Aug 01, 2012 8:02 pm
I know that its an old thread but with what did you wash the underside with racinrob?
Damien89
