Mk3,4,5,6,7 bits.....Bullbar,wind deflectors lockshield etc
Re: Mk3,4,5,6,7 bits.....Bullbar,wind deflectors lockshield
Postby Frag » Thu Nov 17, 2011 8:03 pm
Only picture i have at the minute,vans at work.
Basically its exactly same shape as window internally with tabs all way round to bolt screw or rivet to door.
Made for job not an old bread tray :lol: .
I can get pics but may be mon,Sat at earliest.....
Frag
Ford Technician
Postby Vandalism » Thu Nov 17, 2011 8:57 pm
was just debating if it would fit my van :?
Postby Frag » Thu Nov 17, 2011 10:30 pm
Next time i have the mis-fortune to be at work, i`ll fetch it home & get you some measurements. :)
Frag
Ford Technician
Postby Vandalism » Fri Nov 18, 2011 11:27 am
thanks - i think somone said somwhere the window in a mk5 bulkhead is the same as a mk1/2/3/4 one so im hoping the rear window is a similar size
Postby Leeday » Fri Nov 18, 2011 11:47 am
Hi, Is the bar that protects the rear bumper bolted to the towbar or is it part of the towbar and is it for sale :D Cheers.
1989 Mk3 swb, 3.0 V6 Essex, 5 Speed Manual: http://fordtransit.org/forum/viewtopic. ... 3&t=142054
2005 Mk6 2.0 Duratorq 100 T350 MWB Semi High
Leeday
Postby Frag » Sun Nov 20, 2011 5:11 pm
Its just a piece of angle iron,bolts to bumper with brackets but sort of rests on towbar.
previous owner fitted it.
You can have it for me if you pick it up.......
I`ll probably remove towbar anyhow before van gets squashed.
Frag
Ford Technician
Postby Leeday » Mon Nov 21, 2011 9:17 am
Frag wrote:Its just a piece of angle iron,bolts to bumper with brackets but sort of rests on towbar.
:D ok, many thanks for that, can you keep it for me then and I will sort out a date to come visit you,, I am at j16 of M1. many thanks, Lee. :D
Leeday
Postby Havoc99 » Mon Nov 21, 2011 1:47 pm
wing mirror arrived today
well packaged and in perfect condition
many thanks
Havoc99
Postby Frag » Mon Nov 21, 2011 9:29 pm
Rear window grille measures;
22" deep,55" wide across bottom tapering to 52" at top........
The securing tabs stick out about 1" around the perimeter,if that makes sense :?
Frag
Ford Technician
Postby Vandalism » Tue Nov 22, 2011 11:21 am
thanks frag ill have a measure up
Postby hustler86 » Wed Nov 23, 2011 5:45 pm
got ant pics off the wind deflectors ??
thanks daniel
DONT BE DIPPY LICK A WHIPPY
hustler86
Postby hustler86 » Thu Nov 24, 2011 3:17 pm
hustler86 wrote:got ant pics off the wind deflectors ??
thanks daniel
all so got a price for them :D
thanks agen daniel
hustler86
Postby Frag » Thu Nov 24, 2011 7:02 pm
Everything sold now apart from;
Mk4 (and 3 i guess) Killtech lockshield for steering lock & ignition barrel.
Armoured surround for steering lock/ignition,good deterrant for older vans.....With modified column covers to fit.
Mk3/4/5 Rear window internal security mesh for tailgate vans/tourneo,originally A.A fitment proper thing.
Scrapper also has a full set of 'Custom' bodyside mouldings for a 150S van,(except 1 under fuel cap) which could be re-used,i`ll check condition of these tmrw,i think they're all there and useable
Used fuel cap with a brand new plain key for a mk6 (/7?) bought for a fiesta which are smaller
Thanks.
Frag
Ford Technician
Postby Vandalism » Thu Nov 24, 2011 7:28 pm
forgot to ask your location and price on the window mesh...i think it might just fit
Postby Frag » Wed May 09, 2012 8:43 pm
Ressurected this old thread,still got the following bits only
Mk3/4/5 bullbar,full wraparound thing with spotlight mounts & towing eye built in,has rot in lowest 2 bars so will need them removing/repairing or bodging to some degree......Needs blasting and coating/painting too,got mounting bolts.
Used fuel cap with a brand new plain key for a mk6 (/7?) bought for a fiesta which are smaller .
Will post pics in a bit for interested parties.......Some on previous page
Not sure on prices,make me a sensible offer.Collection preffered but will post if nesc.
Except bullbar ......I may meet for fuel cost within reasonable distance.
Items Nr J36 M1,South Yorkshire.
Frag
Ford Technician
