tonys smiley swb 80 cosworth v6
Postby Guy88 » Sat Jul 14, 2007 7:36 pm
OxtonyxO wrote:fitted my banner today
That is the last banner available in cobalt blue :(
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Re: tonys smiley swb 80 cosworth v6
Postby OxtonyxO » Sat Dec 15, 2007 5:48 pm
not had alot of time to work on the old girl lately, however
i now have factory fitted leccy windows :D
i have boarded out the rear behind the bulkhead with stud wall insulation behind :D
and all so have this to fit 8)
and now the gaydon dates are out, i have a deadline to get the front crossmember,wings, arches and rear arches done :?
roll on the good weather :lol: :lol:
and i still need to find a suitable rear axle to get my ratio and lsd :D
OxtonyxO
Postby Luke » Sat Dec 15, 2007 6:20 pm
OxtonyxO wrote:and i still need to find a suitable rear axle to get my ratio and lsd :D
i'm still undecided over the ratio i want - ive got the 4.11 in now and i can still set off in 2nd :lol:
Postby OxtonyxO » Fri Feb 08, 2008 8:12 pm
well its all official now
Date of Liability 01 05 2008
Date of First Registration 27 05 1998
Year of Manufacture 1998
Cylinder Capacity (cc) 2933CC
CO2 Emissions Not Available
Fuel Type Petrol
Export Marker Not Applicable
Vehicle Status Licence Not Due
Vehicle Colour WHITE
Vehicle Type Approval null
and i received my driver wheel arch from beevers, super fast great service as normal!
so any tips on how to replace it would be very welcome :? :?
OxtonyxO
Postby OxtonyxO » Wed Feb 20, 2008 9:52 pm
looks like i'm in for a busy weekend fitting my new bob cams and time blade :D
just waiting for my vectra injectors then the plenum can go on :D
OxtonyxO
Postby Luke » Wed Feb 20, 2008 9:54 pm
one day i will get all these goodies fitted on mine :lol:
Postby reaper » Tue Feb 26, 2008 10:29 pm
anymore updates on this ? and what sort of money would this cost to do ? why vectra injectors and what that plenum off
reaper
Postby OxtonyxO » Tue Feb 26, 2008 11:35 pm
im still waiting for the injectors :roll: and im fitting them as they flow a little more fuel
mine has cost about :-
£250 for the car
£100 for the adapter, flywheel, exhaust manifolds
£100 for lift pump and swirl pot
£100 bits and pieces (hose and clips)
? ambulance radiator (cant remember)
OxtonyxO
Postby Gavin » Tue Feb 26, 2008 11:47 pm
must admit, its damn tempting at that cost. get a complete car for 400 quid, spend maybe the same again (maybe twice again) getting it in and running. even if it costs you 1200 quid start to finish you cant argue with that for 200bhp. you're not going to get that kind of power and torque cheaper anywhere.
as ive got th pinto efi in my van im already part way there, with the adapter plate on the gearbox and the petrol pump in the tank. if only i didnt have to use the van every day. :(
only problem i can see is theres not many early cossies about now in the ads, most of the cheap ones are the later ultimas with the PATS.
i know people say its a problem, but if you've got the complete car cant you just transfer the PATS stuff over to the van as well, ignition transponder ring etc?
Gavin
Postby OxtonyxO » Tue Feb 26, 2008 11:50 pm
you would need to have the pinto plate redrilled and have the flywheel done too
OxtonyxO
Postby reaper » Wed Feb 27, 2008 12:11 am
mines an ex BT van and so slow would love to have ago at this but wouldnt no where to start or to get the bits from.the bolting in of bits would be no problem its the wiring engine mounts and any fab work.
reaper
Postby mantav8 » Wed Feb 27, 2008 10:23 pm
OxtonyxO wrote:you would need to have the pinto plate redrilled and have the flywheel done too
Tony,Are the adapter plates available?-also the spacer you had machined (i guess it's for the flywheel) where was that from?
Mines a 2.5 Di with MT75 box,so I basically need the same bits as you!
Cheers for any info! :wink:
mantav8
Cosworth Powered
Cosworth Powered
Postby Guy88 » Wed Feb 27, 2008 10:39 pm
the spacer fits behind the torque converter on the granada and needs machining to take a spigiot bearing
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby mantav8 » Wed Feb 27, 2008 10:59 pm
Ah! right,cheers for that,so will come with the car then!
I take it you use the Di flywheel,clutch etc........
mantav8
Cosworth Powered
Cosworth Powered
Postby Guy88 » Wed Feb 27, 2008 11:21 pm
nope
For the flywheel the best would be out of an SVO v6 transit
tony's has the car flywheel and his adaptor plate is modded to suit it
On mine i had a pinto one redrilled and balanced to fit it
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
