Use an electirc solder to melt the plastic , and try to weld it again! and if you can put a reinforcing wire across the crack in U shape. Thats what solved my problem for a broken plastic piece which holds the high tension wire on a Britsh seagul outboard motor.(they are obsolete)
Best soliution is to fit another propeler.
