Preheating and instrument cluster removing
Postby Sinisha » Mon Dec 19, 2022 3:01 pm
Hi
I am a brand new Transit owner. Camper on Mk4 TDI. The instrument lighting is barely visible so I want to check the bulbs. Can anyone help with instructions on how to remove the dash? Below what temperature does preheating kick in?
Sinisha
Re: Preheating and instrument cluster removing
Postby MinorMatt » Mon Dec 19, 2022 3:51 pm
Preheating???? Doesn't exist on a mk4
Lucas Laser 2000 & IDS
95 N Hallmark (white)
96 P 150 TD 100PS LWB Hi-Top
96 P Autosleeper Duetto
2 x 2006 Mk7s
Postby bortaf » Tue Dec 20, 2022 12:54 am
there was a flame start system for artic climates ? if that's what you meen or is there a block heater fitted :?
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby Chug » Tue Dec 20, 2022 1:27 am
It's easier if you take the steering wheel off, but it can be done with it in situ.
Look up at the clocks from under the steering wheel and you will see two screws in the trim surrounding the binnacle, remove them and pull out the trim, then you remove the four screws and the binnacle will come out, but you'll need to reach up behind the dash to squeeze the retaining clip to remove the speedo cable first.
Chug
Postby Sinisha » Tue Dec 20, 2022 9:50 am
Chug wrote:It's easier if you take the steering wheel off, but it can be done with it in situ.
Sinisha
Postby Sinisha » Tue Dec 20, 2022 10:05 am
No preheating? Only Mk4? I heard something about that, but I figured that's some strange option for certain markets .... :?
In Owner manual is stated that when engine is cold preheating may occur and lamp will lit. So, no problem when cold with these engines? My old Iveco has Thermostarter, flame torch in air inlet. Kicks in only when engine cold and outside temps are below 2C.
Is the lack of preheating the reason for the two batteries in some models? I have one battery, as usual. The place for the second one is occupied by a leisure battery.
So if my Transit has a preheater, then it's a Torch in air inlet, like my former Iveco?
Interesting ....
Sinisha
Postby gotgcoalman » Tue Dec 20, 2022 8:41 pm
Good battery/batteries,good starter and good connections=vroom.
No need for the glow plugs with the MK3/4/5.
Only lipstick wearing Mk6/7 types need them.
Remember our Ukrainian friend posting a video of a proper cold weather start up.
Sent from my ONEPLUS A6003 using Tapatalk
Too bloody quiet :shock:
gotgcoalman
Postby Sinisha » Wed Dec 21, 2022 8:50 am
Ha, that's great. Could you give me a link for "... our Ukrainian friend posting a video of a proper cold weather start up", please?
Sinisha
Postby bortaf » Wed Dec 21, 2022 10:57 pm
flame start posts
viewtopic.php?t=61657
viewtopic.php?t=121044
Flame heater glow plug Ford Transit 1986-2000 for sale, cant find anything on the rest of the system though :(
https://www.transitcenter.uk/flame-heat ... f97c3780ab
PART NUMBER:
92VB9N424BA , 92VB9N424BA
95VB9N424AA , 95VB9N424AA
92VB9N424AA , 92VB9N424AA
FINIS:
6748697
7122513
As good as this forum is the search is pretty bad your better off just googling the subject :wink:
Current fleet
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
