Mk3 armoured van
Re: Mk3 armoured van
Postby Eugene Speed » Sat Mar 16, 2013 8:46 pm
I can't find any makers plate on mine so was hoping it had come from the same stable, but obviously not! :lol:
I will have a look at the SVO brochure you speak of.
91 Transit County 4x4
88 Transit 130 armoured van
99 Transit spec lift
90 Fiat Panda 4x4
http://facebook.com/eugene.speed
http://tuffcomputercompany.com
http://transitcounty4x4.co.uk
http://truthsearchersuk.org
Member of the Mk3 Massive! :)
Eugene Speed
Postby FredTransit » Sat Mar 16, 2013 9:29 pm
FredTransit
Mk2 Trannyist
Re: Mk3 armoured security van PV18
Postby Eugene Speed » Fri Mar 22, 2013 5:46 pm
Not too impressed, the van has developed an annoying problem. Under acceleration there is a sudden decrease in power, like the engine is holding back, then it starts to pick up power again. This is now accompanied by the smell of fuel when the engine is switched off, I have had a good look in the engine bay and can't see any obvious leakage anywhere. Any suggestions before I start pulling the fuel system apart?
90 Fiat Panda 4x4
Eugene Speed
Postby Luke » Fri Mar 22, 2013 6:26 pm
fuel filter :?: :D
Postby Vandalism » Fri Mar 22, 2013 7:42 pm
carb not set up properly?
that was the problem on my my capri
Postby FredTransit » Fri Mar 22, 2013 8:01 pm
sure its a diesel. Check the fuel line as it passes behind the rocker cover. They can rub and let in air.....
FredTransit
Mk2 Trannyist
Postby Eugene Speed » Fri Mar 22, 2013 9:52 pm
Fuel filter is new as of June 2012, however the fuel line getting split would make sense. I shall have a poke around with a torch and a mirror next week, I'm sticking with the County this weekend if the snow is threatening to show up round here! :wink:
90 Fiat Panda 4x4
Eugene Speed
Postby transitandy » Sun Mar 24, 2013 4:05 pm
You cant beat a transit 4x4 in the snow 8) 8)
Postby captain hook » Sun Mar 24, 2013 6:02 pm
transitandy wrote:You cant beat a transit 4x4 in the snow 8) 8)
It ain't 4x4 Andy :roll: :roll:
captain hook
Postby madbri » Sun Mar 24, 2013 9:29 pm
i had the same problem for 2 years :evil: :evil: tryed the tourque sleeve changed filter fuel pipes still the same :evil: then my sisters cargo played up and that solved it for me :roll: sisters cargo lost power so i changed the filter ect still the same :roll: it was a cable stop solonide and the cable had slipped ie not holding the stop of completely. so i checked my voltage at mine and that was ok :twisted: so i changed it and geuse what :roll: it flew the best it ever had. so i recon the solon9ide had got week. and to prove it i changed it back a mounth later and the symptons return till i binned it fitted another soliniod
madbri
Postby FredTransit » Mon Mar 25, 2013 10:22 am
good thinking bri, stop solenoid. The wire that comes off it too. Had trouble with that half way accross France once.
FredTransit
Mk2 Trannyist
Postby Eugene Speed » Thu May 02, 2013 2:24 pm
Found an old step bumper off a Mk5, a bit rough but it will do for now!
90 Fiat Panda 4x4
Eugene Speed
