Mk6 to mk7 front end conversion Pics
Postby looneyfitter » Thu Jan 02, 2014 5:41 pm
Well today I started my conversion. I removed all the front end and phoned the Breakers to see if they had any mk7's in.. Haven't rang me back yet,
I will add pics later on tonight.
Question tho for others that have done it before. Is the main reason for changing the windscreen scuttle just so you have the bracket to support the window wiper mechanism??
I'm thinking I could make a bracket easy enough if that's the case.
I WILL GET THIS FEcKER RUNNING!!!
looneyfitter
Re: Mk6 to mk7 front end conversion Pics
Postby t2myd » Thu Jan 02, 2014 6:33 pm
What parts do you need ?
Transit vantastic !!!!!!
t2myd
Postby looneyfitter » Thu Jan 02, 2014 7:16 pm
Need the scuttle and the top inner wing reinforcers mate
looneyfitter
Postby karl » Thu Jan 02, 2014 7:31 pm
search.php?keywords=punto+conversion
thread above mate take ya pic from diffrent ones
good info
karl
Tranny Lover!!!
Postby looneyfitter » Thu Jan 02, 2014 7:42 pm
Not sure why you've put that link matey. Thanks tho. Lol must already read most of them 100 times :-)
looneyfitter
Postby t2myd » Thu Jan 02, 2014 8:15 pm
There the only bits I don't have
t2myd
Postby Punto443 » Thu Jan 02, 2014 8:20 pm
Cheap enough from ford :D
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Postby looneyfitter » Thu Jan 02, 2014 8:33 pm
Punto443 wrote:Cheap enough from ford :D
not in stock at my local tho mate..
Thanks t2
looneyfitter
Postby t2myd » Thu Jan 02, 2014 8:39 pm
Is there no bits at hills salvage ?
t2myd
Postby chrismidnite » Thu Jan 02, 2014 8:43 pm
looneyfitter wrote:Need the scuttle and the top inner wing reinforcers mate
I doubt these will have been removed by the breakers and would be a lot of work to take them off to reuse. My local Evans Halshaw got the wing & scuttle parts I needed on next day delivery.
chrismidnite
Postby t2myd » Thu Jan 02, 2014 8:47 pm
Probaly only way of getting them is on next day delivery from ford , at least parts will be new , so no messing about
t2myd
Postby looneyfitter » Thu Jan 02, 2014 8:58 pm
t2myd wrote:Is there no bits at hills salvage ?
Thats who i rang today mate waiting for them to call back.. The upper wing is only 5/6 spots so should be easy enough, just going to mod the lower wing to fit. ...Im hoping they will cut the scuttle at the screen for me. WOnder if they will let me loose in there with my wizzer.... Dont really wanna pay £100 for parts either tbh as im selling it.
Do you know of any othere breakers local to us that you can take your own bits off?
looneyfitter
Chris did you take any pics of the leg mod mate?
looneyfitter
Postby scrapman2013 » Thu Jan 02, 2014 9:03 pm
go breakers yard with a good cordless drill and a spot weld drill bit that's wot I did took bout 45 min to get them off cost 30 quid
scrapman2013
Postby looneyfitter » Thu Jan 02, 2014 9:04 pm
scrapman2013 wrote:go breakers yard with a good cordless drill and a spot weld drill bit that's wot I did took bout 45 min to get them off cost 30 quid
was that with the scuttle too?
looneyfitter
