Oil pump recall
Oil pump recall
Postby Guy88 » Fri Aug 15, 2014 11:10 am
Anyone else heard this yet.
Was in a ford today dropping another mk7 and have been told by service there that there's a modified oil pump being fitted to the 2.2 euro 5 engines in the mk7 and custom.
Maybe ford have worked out there's an issue at long last
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Re: Oil pump recall
Postby karl » Fri Aug 15, 2014 1:45 pm
Guy88 wrote:Anyone else heard this yet.
all years ? big job to change one engine out jobby
karl
Tranny Lover!!!
Re: Oil pump recall
Postby andrusl » Fri Aug 15, 2014 3:05 pm
Model/Variant Assembly Plant Affected Build Periods (inclusive dates)
Transit -- Kocaeli from 1/10/2011 to 4/10/2013
3S549 - Transit Puma Oil Pump
Affected vehicles will be identified on OASIS. This Service Program is limited to only those vehicles that have been identified as high mileage usage / or with specific drive cycle conditions, within the build range shown below.
andrusl
Re: Oil pump recall
Postby 125neil » Fri Aug 15, 2014 3:35 pm
I presume the engines are built in various countries, the engines are supplied to other manufacturers so is it just engines built in Turkey specifically for Transits that are affected ?
125neil
Re: Oil pump recall
Postby jay » Fri Aug 15, 2014 5:14 pm
wonder if this affects landrover 2.2 engines in the defender as well..Big recall on defender front axles at the moment from pinion seal and bearing..
mk1 connect tourneo
jay
Re: Oil pump recall
Postby V184 » Fri Aug 15, 2014 5:51 pm
all years ? big job to change one engine out jobby[/quote]
i was told a 3hr job :roll: . :?
V184
Re: Oil pump recall
Postby dieseldel » Fri Aug 15, 2014 7:41 pm
hi
not an engine out job, timing cover and sump off, tensioner off, oil pick up pipe off,undo 4 bolts and its off
it was like that before i touched it !!
dieseldel
Re: Oil pump recall
Postby V184 » Fri Aug 15, 2014 8:10 pm
Does this mean if you have had an engine go pop as a result of oil pump failure out of warranty you will be refunded the price of an engine ?
V184
Re: Oil pump recall
Postby blue estate » Fri Aug 15, 2014 9:36 pm
V184 wrote:Does this mean if you have had an engine go pop as a result of oil pump failure out of warranty you will be refunded the price of an engine ?
And I will fly pig airways on holiday :wink:
blue estate
Re: Oil pump recall
Postby ake » Fri Aug 15, 2014 10:05 pm
125neil wrote:I presume the engines are built in various countries, the engines are supplied to other manufacturers so is it just engines built in Turkey specifically for Transits that are affected ?
Pretty sure engines are built in uk.
Re: Oil pump recall
Postby jr71 » Fri Aug 15, 2014 10:10 pm
Is it only euro5 ?
57 plate transit connect
V reg mk5 transit (gone for restoration to Durham)
56 plate mk7
jr71
Re: Oil pump recall
Postby Guy88 » Fri Aug 15, 2014 10:50 pm
jr71 wrote:Is it only euro5 ?
only the 2.2 euro 5 are affected, meaning MK7.5, MK8, custom, L/R, peugeot boxer and citroen relay
more chance of getting a blow job off the pope :roll:
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Re: Oil pump recall
Postby Guy88 » Fri Aug 15, 2014 10:52 pm
however i dropped a 2012 euro 5 in the other day for oil light on (no supprise oil pump gone) and they said that ones not affected as its low milage
wonder how the MK8 i picked up blown up will fare :lol: :lol:
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Re: Oil pump recall
Postby 125neil » Sat Aug 16, 2014 8:29 am
Guy , if you're in Ford early next week could you ask the service lad a bit more about this, as for it being paid for by Ford if out of warranty I would say why not, Its obviously cheaper to replace the pump before the engines break so I wonder if owners will be notified of a recall.
125neil
Re: Oil pump recall
Postby V184 » Sat Aug 16, 2014 9:27 am
jay wrote:wonder if this affects landrover 2.2 engines in the defender as well..Big recall on defender front axles at the moment from pinion seal and bearing..
Handy then you can change the oil pump at the same time :lol: :lol: :lol:
V184
