help!!! 2.5 TD head?
Postby MrMPuk » Sun Oct 23, 2005 8:52 pm
Does it mention anything in the haynes manual about a further 90 degress after torquing?
Postby 100ps_drw_hicube » Sun Oct 23, 2005 9:06 pm
ye it says something about another 90 degrees i take it means turn bolt another 1/4 of a turn??
100ps_drw_hicube
Transit Abuser!!
Postby Luke » Sun Oct 23, 2005 9:11 pm
100ps_drw_hicube wrote:ye it says something about another 90 degrees i take it means turn bolt another 1/4 of a turn??
yep!!
did you do that?
Postby 100ps_drw_hicube » Mon Oct 24, 2005 8:25 am
ye i went another 1/4 of a turn but talking to somone who used to be a mechanic he said it dont seem very tight for head bolts ? anyway the haynes manual says 52 lbft i will ring someone at fords today and see what they think
100ps_drw_hicube
Transit Abuser!!
Postby MrMPuk » Mon Oct 24, 2005 4:11 pm
This is what Ford says, the haynes manual is right, althought the torque setting is quite low the extra 90 degrees makes it quite tight.
Head bolts are 70Nm + 90 degrees.
Postby 100ps_drw_hicube » Mon Oct 24, 2005 4:18 pm
thanks for diagrams yep they are exactly the same as haynes manual got a new head gasket today and refitted head got everything back on execpt rocker cover have just got to check the valve clearances then we will see what happens in the morning to wet to stay out there any longer :( hopefully all will be well tommorow if not then no ideas yet again thanks everyone for your help :D :D
100ps_drw_hicube
Transit Abuser!!
Postby MrMPuk » Mon Oct 24, 2005 4:21 pm
You should have done the valve clearences before when you did the head, as you moved them when removing the rockers! Are you doing them hot or cold?
Postby MrMPuk » Mon Oct 24, 2005 4:23 pm
Also another thing to check if it's still smoking as you fitted a new head, do you know what the enigne was like that the head came off of as it might be the valve stem oil seals!
Postby 100ps_drw_hicube » Mon Oct 24, 2005 4:53 pm
the haynes manuals says the same for hot or cold valve clearances.. the head was a brand new head which came from a local person who used to run a fleet of mk5 td's so it is definately the correct one!! wish i had left it alone but i couldnt put up with the blue smoke the stem seals had gone!! also my first post somone mentioned one of my probs could be that the rings had gone they say said to check i had to pour diesel into the bores and see what happens whats is meant to happen????
100ps_drw_hicube
Transit Abuser!!
Postby MrMPuk » Mon Oct 24, 2005 5:02 pm
Had the stem seals gone on your old head? Is that why you changed the head? Surely it would have been easlier just to change the seals?
When you say new head, had it been stored?
If you poor diesel in the bores and then leave it for a while and come back if the diesel is still at the same level then the rings are ok if it has dropped then the rings could be knacked.
Postby Luke » Mon Oct 24, 2005 5:04 pm
100ps_drw_hicube wrote:i had to pour diesel into the bores and see what happens whats is meant to happen????
should drain evenly - not sure how long it should take - it will be quite a while - but be aware when doing this the diesel will drain into the oil - so remove that first then drain the diesel out of the sump - then put the oil back in!! :D
Postby 100ps_drw_hicube » Mon Oct 24, 2005 5:50 pm
i tried it when i done the head last week 2 inner cylinders took over 5 hours to drain through the 2 outer cylinders took about 4 hours to drain is this likely to be a problem?? i changed the oil as it was full of water :lol:
100ps_drw_hicube
Transit Abuser!!
Postby MrMPuk » Mon Oct 24, 2005 5:59 pm
No that sounds about right.
Postby Luke » Mon Oct 24, 2005 6:02 pm
When you fitted the headgasket did you clean the block surface fully to make sure all trace of the old head gasket were gone :?:
Postby 100ps_drw_hicube » Mon Oct 24, 2005 6:28 pm
ye it was pig to get the old off but i took my time and made sure it was spotlessly clean
100ps_drw_hicube
Transit Abuser!!
