P1631
P1631
Postby erikdcc » Fri Jan 28, 2011 2:07 pm
Hello everybody, I have a 03 transit 350 90PS, was driving along all over sudden the van cut out, and would not start again, got it towed home, scanner reading was P1631 Main relay problem, changed all the relays underneath the Bonnard but no joy, the van just will not start, starter motor is turning over no problem, I was wondering if anyone can help?
Best regards Eric
erikdcc
Re: P1631
Postby TIMO » Fri Jan 28, 2011 2:18 pm
BBC = British Broadcasting Conspiracy
http://www.youtube.com/watch?v=nj82wxnO ... r_embedded
TIMO
Re: P1631
Postby DiscoDan » Tue Oct 20, 2015 11:39 pm
Sorry to bring up an old thread but I've pretty much got the same problem, same van, just randomly cut out on the motorway whilst I was away in France, got it brought back home and I just get the P1631 code, if I clear it then try to start it again, the code reappears.
I've posted a quick video of what it does when I try to start it: http://vid193.photobucket.com/albums/z20/discodaniel11/Mobile%20Uploads/IMG_7016.mp4
So far I have had a quick nosey over some of the wiring.
Swapped a few relays around to test.
Cleaned up my battery connections.
Also put on a spare starter I had - Checked the voltage to the starter an that's fine.
Does anyone have any advice? Thanks in advance :)
Mk6 125ps Jumbo Camper conversion - fitted with 4.63 diff
DiscoDan
Re: P1631
Postby paul2012 » Wed Oct 21, 2015 1:00 am
DiscoDan wrote:Sorry to bring up an old thread but I've pretty much got the same problem, same van, just randomly cut out on the motorway whilst I was away in France, got it brought back home and I just get the P1631 code, if I clear it then try to start it again, the code reappears.
Too possibilities...
1. Battery Useless - May have volts but not enough cranking amps. :!:
2. Lazy starter motor.
I would replace battery first. :wink:
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Re: P1631
Postby DiscoDan » Wed Oct 21, 2015 8:58 am
paul2012 wrote:Too possibilities...
Thanks Paul, I'll swap the battery today for a known good one an report back. Glad their inside on these, obviously out comes the rain when work needs doing! :|
DiscoDan
Re: P1631
Postby ake » Wed Oct 21, 2015 9:02 am
That code will always appear if the battery is low, or after repeated cranking attempts
It's almost never the relay at fault!
Re: P1631
Postby DiscoDan » Wed Oct 21, 2015 12:00 pm
Okay so I swapped out the old battery and it defiantly feels/sounds much stronger now, but still won't start.
I cleared the code an none have returned.
Made a quick clip of what it now does: http://vid193.photobucket.com/albums/z20/discodaniel11/Mobile%20Uploads/IMG_7049.mp4
It's like it wants to do it but somethings stuck, you can feel through the gear stick. I defiantly know the other starter I put on works.
I usually start it clutch down, not making any difference to this situation though.
I was doing around 67mph when it just randomly cut out, I didn't hear anything out of the ordinary :/
Thanks for the help :)
DiscoDan
Re: P1631
Postby paul2012 » Wed Oct 21, 2015 4:05 pm
Providing it's got a good battery.
1. Lazy Starter motor - May work ok on the bench. When fitted, don't have the strength to crank engine over.
2. Check GND strap from battery to floor.
3. Check GND strap front N/S chassis to Engine.
If all of the above is ok.
4. Get a socket on crank pulley & see if you can rotate crank by hand - This will rule out a seized engine.
paul2012
Re: P1631
Postby loot » Wed Oct 21, 2015 4:25 pm
I'd check that the engine rotates next, something is killing the power :-(
07 350 170ps
Ids map here
loot
Re: P1631
Postby DiscoDan » Wed Oct 21, 2015 7:11 pm
Ok cheers guys.
I Just popped out to try rotate crank, couldn't fit with my breaker bar or wrench though as the viscous fan was in the way, guess my socket is too long :wink: :lol:
So just had a quick go with the spanner, not much leverage I know so wasn't able to turn it clockwise, was able to go anti-clockwise a little though (not sure if that's ok to do or not), before the bolts then obviously started to unscrew.
Tried to start it an it seemed to spin then get stuck at the same point where it originally was again an would go no further, did this twice with the same result, the second time I recorded it, hopefully I haven't made things worse :|
Here's what happens, recorded it from underneath this time: http://vid193.photobucket.com/albums/z20/discodaniel11/Mobile%20Uploads/IMG_7060.mp4
Do you think I'll have to take the cover off? Or should I try turning it clockwise properly before that?
DiscoDan
Re: P1631
Postby loot » Wed Oct 21, 2015 8:35 pm
It's looking a bit stuck :-( when the engine died did it getting to a sudden halt or rotate to a stop? Can you try backing off further then rotate tool it locks? Just trying to confirm that something is catching.
You don't really want to force it tho tbh, is it possible that the timing chain has snapped or something like that.
You may have also snapped a con rod but they usually pop out of the block to say hello.
Fingers crossed it is the starter but it is engaging and turning a bit, it just seems that there is a stop on the engine tho :-(
If you put your bar on 1 bolt and another socket on another nut, you may be able to have the 1 leaning on the other to rotate the pulley without undoing the bolt. :-) failing that, put 2 sockets on 2 bolts and a bar between them and lever round to rotate.
07 350 170ps
Ids map here
loot
Re: P1631
Postby DiscoDan » Wed Oct 21, 2015 9:08 pm
Indeed it is :( I'd say more of a rotate to a stop, only because there wasn't any sudden jolt or anything. Just some vibration as I was rolling along briefly still in 5th which stopped when I quickly depressed the clutch an back to neutral.
Yeah I'll have another crack at it tomorrow in the light perhaps, I think I get what you mean in regards to the pulley, makes sense in theory anyways :) shall let you know how it goes. No signs yet of an uninvited rod popping out to see the world :shock: hopefully it stays that way haha :P
Only did the chain, revised tensioner etc just over a year ago, genuine too :|
DiscoDan
Re: P1631
Postby loot » Wed Oct 21, 2015 10:20 pm
Yes I'd be interested to know how you get on :-)
Obviously at this stage it could be anything Lol but if the engine is locking up then that needs investigating.
07 350 170ps
Ids map here
loot
Re: P1631
Postby DiscoDan » Thu Oct 29, 2015 7:58 pm
Felt nice an energetic today so whipped the front off, much better access! along with the timing cover (needs doing anyway as its leaking in places).
Now from this position, say 1 o'clock (referencing the bolt on the crank) I rotate it clockwise almost fully...
...But then it stops at around 11 o'clock and will go not further...
and vice-versa, it won't complete a full rotation :|
DiscoDan
Re: P1631
Postby loot » Thu Oct 29, 2015 11:41 pm
You need to take the rocker cover off and watch the valves moving when you rotate, with the injectors out it should be easier to turn, you may get a long thin bar or something and put it down the injector holes 1 at a time to see if the pistons are moving as they should.
I've not done all that on my van so the info is based on an older petrol engine but hopefully the same applies.
I'm thinking a broker con rod and it is catching somewhere but i hope I'm wrong :-(
07 350 170ps
Ids map here
loot
