mk6 ASM transit moves 1 meter then drops out of gear
Postby blfmtriv » Thu Aug 11, 2016 4:00 am
Hi i,m a newbie from way up here in the Top End
services are pretty limited out here so you have to give everything a go first
i have a mk6 transit 2004 ASM 2.4 duratec that i have just replaced the tail shaft , as the yard picked the transit up with a forklift and bent the rear shaft
before this the transit drove , but only up to 30kph before the vibrations came in from the bent shaft,
now that i,ve got a new rear tail shaft made, i cannot drive it
i put it into gear it flashes and as i pull off it drops out, same with reverse
have checked and confirmed bonnet switch ok and working, and door switches working
checked all fuses ok
could there be something in the gear box, it was awfully tight and i did slightly rotate the gearbox shaft as i was undoing
the loctite bolts
or could i have spiked the system by jump starting to many times, as once the cables did touch
please can i have your thoughts, the chooks are already eyeing off a new home :lol:
thanks
andrew , top ender
blfmtriv
Re: mk6 ASM transit moves 1 meter then drops out of gear
Postby AndyG » Sat Aug 13, 2016 12:22 am
Sounds like a spike problem.
Try disconecting the battery/ies overnight. Leave ign. on to get rid of any residual voltages.
Postby blfmtriv » Mon Aug 15, 2016 12:59 am
thanks mate i,ll give it a try :D
blfmtriv
Postby blfmtriv » Tue Aug 16, 2016 5:57 am
ok tried the battery off ign on over nite , no luck
i have gone through every relay, fuse again to make sure, it seem like a security thing as i can put the rear wheels up and
spin them, but as soon as i move 1 mtr you can feel the thing let go
any thoughts people
thanks andrew
blfmtriv
Postby blfmtriv » Tue Aug 16, 2016 9:04 am
ok test number 3
i have disconnected the speedo plug from the end of the gearbox, this enabled me to drive the van around the property in first gear
so i can say that there,s no issue with the gear box, it appear to be electrical
i cannot change the load status on the dash just sits on E
ant thoughts people please
andrew from remote NT
blfmtriv
Postby blfmtriv » Wed Aug 17, 2016 11:15 pm
hi all, i found the fuse in the asm (fuse 1) was a 15 amp not a 5amp as specified,
is the bonnet switch normal open or closed when the bonnet is down?
thanks
blfmtriv
Postby AndyG » Mon Aug 22, 2016 12:31 am
With bonnet closed, I would think it would be open circuit.
Dashboard modules have been known to become faulty.
Check and replug it a couple of times and see if this cures it.
Door switches MUST work properly for the system to work.
Postby blfmtriv » Mon Aug 22, 2016 2:08 pm
andy mate whats a dash board module
just got back fro kalkaringi nt and theres plenty of transit mk 8 out there going ok
so there are reliable
cheers'
andrew
blfmtriv
Postby AndyG » Tue Aug 23, 2016 12:08 am
The unit that you press the D button etc and displays what might be happening.
Postby blfmtriv » Fri Sep 02, 2016 12:04 pm
Today my ford super f reader arrived from the uk, cost $56,and works on windows 10
plugged the computer in after down loading the program and read the error code, can someone please explain the code to me
below is a copy of the code,
also is the bonnet switch the same as the driver door switch, N/C WHEN DOOR IS CLOSED AND BONNET DOWN?
What is B1205-Electronic instrument cluster switch bank number 1 circuit failure?
thanks
andrew
blfmtriv
Postby AndyG » Fri Sep 02, 2016 10:50 pm
Can't be 100%. But does sound like the module I've posted above.
You say the status load button doesn't change/work.
Is the popper button not working? It could be all that's wrong?
Postby blfmtriv » Sun Sep 04, 2016 10:30 am
gday mate
whats a popper button?
yer i reckon it getting doen to the 2 switches as one was u/s and the new bonnet was slightly out
so i,m thinking of bridging the switches,
or either getting 2 new ones
blfmtriv
Postby blfmtriv » Mon Sep 05, 2016 5:46 am
problem has been solved and rectified
ok for the record
bonnet switch and door switch for safety function, these switches are normally open when the bonnet is closed and door closed
the bonnet switch had malfunctioned, causing this,
once the fault was detected it could not be reset by battery disconnection
as stated above i purchased a ford f super version 2 from the UK, THIS TOOL IS EXCELLENT DIAGNOSTICS
i could only reset DTC whilst the engine was running and this did the trick
i reset all DTC and the van runs perfectly smooth in all gears,
end of problems
blfmtriv
