Advice on roof consoles!
Postby Luke » Tue Jun 12, 2007 10:23 pm
been doing a bit on this - ive made a cardboard mock up - im gonna fit that 1st just to check i can reach all the buttons and see all the gauges etc. then make it out of mdf backed in vynalette :D
this is the pic of it i did on paint - its not to scale but all the gauges switches actually fit in that position on the scale 1:1 version :D
The middle bit is the CB and that is raised out further- above it is a clock and each side of that are the electric window switches - the brown box is the head unit above them are switches and to the right gauges :D far left is a glove box and far right is a panel containing lights - i need a panel to go on last so i can reach in and bolt it in place - that way any mounting bolt heads can be seen 8)
opinions anyone :?:
Postby Luke » Mon Jun 18, 2007 7:58 pm
just been to wickes and got some 9mm mdf for this :)
watch this space :lol:
Postby snap-on » Mon Jun 18, 2007 9:29 pm
good luck Luke :lol:
Dave
snap-on
Postby sidspop » Tue Jun 19, 2007 5:57 pm
Your cb will work much better in that location if you run a seperate earth wire or two to the steelwork of the van. You'll get less interference.]
sidspop
Location: The Black Country (near to Brummagem, but not the same)
Postby bigmastif » Tue Jun 19, 2007 6:36 pm
Luke wrote:just been to wickes and got some 9mm mdf for this :)
good choice of company to buy yer wood from luke proud of ya :wink: :lol: if ya had been in scotland i coulda got you it for much much cheapness :lol: :lol:
bigmastif
Postby viper » Tue Jun 19, 2007 7:53 pm
Isnt plywood more suited to this kind of role, strength, swelling etc, just a wee thuoght
viper
Postby sidspop » Tue Jun 19, 2007 8:20 pm
Depends how many holes are in the roof..... :wink:
sidspop
Postby Luke » Tue Jun 19, 2007 8:22 pm
sidspop wrote:Depends how many holes are in the roof..... :wink:
none that let in water anyway :lol:
i just thought MDF is easier to work with :? :D
Postby sidspop » Wed Jun 20, 2007 9:14 pm
Wear a mask, MDF is carcinogenic. Allegedly
sidspop
Postby mrgasoil » Wed Jun 20, 2007 9:30 pm
WHY BE CONCERNED ABOUT MDF?
In all fibreboards, formaldehyde resins are used to bond together the
constituent parts. This is usually urea formaldehyde, but some fibreboard
including exterior or marine quality board will use stronger glues such as
phenol formaldehyde.
Even at a low level, exposure to formaldehyde though inhalation can cause
irritation to the eyes, nose, throat and mucous membrane. Formaldehyde can
also affect the skin, leading to dermatitis, and the respiratory system
causing asthma and rhinitis. The International Agency for Research on
Cancer (IARC), part of the World Health Organisation, quoted evidence that
even short term exposure to formaldehyde, at far below the legal limit
allowable in Britain, could cause irritation to the eyes, nose and throat.
The IARC's findings also stated that wood dust is a carcinogen' (cancer
causing) and that 'formaldehyde is probably carcinogenic to humans'. IARC
was also concerned about the reproductive hazards of formaldehyde'.
Formaldehyde is classified in the UK and throughout Europe as a Category 3
Carcinogen. This means it is a substance which "causes concern for humans
owing to possible carcinogenic effects but, in respect of which, available
information is not adequate for making a satisfactory assessment." This
puts formaldehyde on the GPMU list of potential carcinogens, meaning it
should be replaced where possible, and if not, subject to rigorous controls
that reduce exposure to the lowest possible level.
taken from http://www.childrensfurniture.co.uk/mdf.html
mk5 flareside with tail-lift GONE and will be missed!
Mk6 T350 LWB DRW dropside with tail-lift.
mrgasoil
Postby OxtonyxO » Wed Jun 20, 2007 9:31 pm
what about this for your cb
looks 8)
http://www.kcb.co.uk/shop2/
OxtonyxO
Postby Luke » Wed Jun 20, 2007 9:44 pm
OxtonyxO wrote:what about this for your cb
looks 8)
thats a fine CB tony but.......... to modern looking for my van :)
i was thinking of getting another rotel 240 like ive got - mainly becase the mic plug is on the side and i can hide the lead behind the console - unless im using it then i can pull it all out :idea: :lol:
Postby Luke » Wed Jun 20, 2007 9:48 pm
oh and mdf advice noted :wink:
Re: Advice on roof consoles!
Postby thebaldconvict » Sun Mar 13, 2011 4:45 pm
Sorry to dig up such an old thread, I've been thinking of making a few of these for my minibus but how are they securely attached up there?
thebaldconvict
Postby StuartB58 » Sun Mar 13, 2011 9:33 pm
thebaldconvict wrote:Sorry to dig up such an old thread, I've been thinking of making a few of these for my minibus but how are they securely attached up there?
Glad you dug this up as I've been thinking about doing the same. Luke how did you get on? any pics?
Anyone done this to a Mk5?
MK6 Twin wheel 2.4 in white
Ford where rust is NOT an option.
StuartB58
