loot wrote:Front and rear axles need to match don't they? You'll be burning against each other I would think?
Airthies wrote:One thing I was trying to do but couldn't was increase the tyre diameter, but even going through all the engineering codes I've found there's nothing, but wondering if a change in diff ratio would be too big a jump to correct the differences between diameters and Speedo.Need to get my math's head on
Sent from my A55ho11 using Crapatalk
loot wrote:I wonder though will the biggest option be the standard 16s at 2205 or whatever?
I had 255 55 18 on my mk7 and they were 9mm larger diameter but close enough
Cider Andy wrote:loot wrote:I wonder though will the biggest option be the standard 16s at 2205 or whatever?
2317.5mm rolling circumference, I reckon.....
Airthies wrote:...rolling circ of 2337...
Not that muchCider Andy wrote:Airthies wrote:...rolling circ of 2337...
What numbers have you got in the drop down list?
can't remember off top of my head but must be same as everyone else, think it's 22 something
Nah it can wait, I need to plug in and reactivate RCL tonight,(and that's all) as last night while buggering about trying things I turned it off then forgot to turn it back on again so it's been say open over night and today againloot wrote:The only 2 useful options I found were engineering mode and rcm mode.
The rest I didn't find much response to and any I did I didn't know what I was doing so stayed away from the big red button as it were.
I would have liked to done a new vehicle configuration that allowed me to write a 140ps map over the 130ps map. I'll have to do it manually though, just need to wait until someone is passing in a sport vanbeep beep loot.
Anyway did you solve the speedo conundrum?
by the time I finished last night I couldn't be arsed plugging back in as it was nearly morning already.
