tranmx2 wrote:Easier to work on it when out of location. Likely a new barrel is needed. The electric connections are at the other end.
Other posts re' key, barrel, electrics on the forum.
Better to know the year, emissions, VIN etc of the vehicle.
crowlands27 wrote:tranmx2 wrote:Easier to work on it when out of location. Likely a new barrel is needed. The electric connections are at the other end.
It's 2011 and I've added pics if that helps.
How would I remove the barrel if I can't get the ignition to rotate? Thanks
eskimodoodle wrote:yes best to always put a steering lock and a pedal lock on vans .
Tip: remember to put the key side of steering lock away backwards as otherwise they can just drill the key hole on steering lock .
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot]
