What did you do to your Custom today?
Re: What did you do to your Custom today?
Postby ake » Thu Mar 30, 2023 8:17 pm
ned wrote:So your back in a transit now mr ake sir
Yes mate, I’ll have been back self employed and in a Transit for 3 years in June
Postby ulyssesmeads » Sat Apr 01, 2023 10:41 am
wash, wax, and tire shine!
ulyssesmeads
Postby ulyssesmeads » Mon Apr 03, 2023 9:30 am
I replaced the engine air intake filter and wiper blade.
ulyssesmeads
Postby sherwoodcycles » Sat Dec 16, 2023 2:49 am
I just fitted a new turbo actuator. Calibrated it with forscan and swore a lot trying to use forscan afterwards as it decided not to connect.
Greeny
sherwoodcycles
Postby sherwoodcycles » Sun Dec 17, 2023 9:41 pm
Yesterday night, I gave my vapouriser a blow job. I unplugged it. Let the diesel dribble out, then ran the engine blocking the exhaust to force fumes out of the vapouriser. I then put the plug in my mouth and blew. I was able to blow through it despite violating my mouth. At least I know its not blocked.
Greeny
sherwoodcycles
Postby sherwoodcycles » Wed Mar 27, 2024 12:35 am
Bought some spotlights- they were rubbish. Took the internals out and fitted them to my rear lights
Greeny
sherwoodcycles
Postby mafty » Wed Mar 27, 2024 6:52 pm
Finally got my SYNC 2.5 upgrade fully working, including CarPlay!
Details here...
viewtopic.php?f=65&t=227191
Di! Ecce hora! Uxor mea me necabit!
mafty
Postby t0m541 » Fri Jun 21, 2024 2:34 pm
Painted the standard Ford alloys satin black...with my usual apply by catapult standards of brush painting
15 plate Custom 2.2 Trend eTech in black, it's so good to be back in a Transit...
t0m541
Postby t0m541 » Sun Jun 23, 2024 9:40 am
Stripped the rear discs/hubs off to change the discs and pads and found the bearings rusted in solid to the disc.
Removed the very crusty silencer and straight piped the exhaust, sounds sweet.
t0m541
Postby t0m541 » Tue Jul 09, 2024 8:05 pm
Spent another couple of hours trying to program up my new key fob.
After trying Forscan with no luck, I bought a OBD unit from a company called FobFix.
From the instructional video it should have been plug and play and about 5 minutes.
But...as is my luck, the OBD box couldn't communicate with the ECU according to the flash code on the box, from what the guy at FobFix explained.
But as Forscan and my other Scantool connect and communicate without a hitch, FobFix are sending me another programmer to test.
Also whilst digging about with Forscan, I went into the module programming section, discovered that the "wrong" tire size was in the system.
It said 15" wheels but the van has 16" factory alloys, so that got updated plus a few other bits that were not enabled but the van has.
t0m541
Postby loot » Sun Jul 14, 2024 9:44 pm
t0m541 wrote:Spent another couple of hours trying to program up my new key fob.
I have the forscan and vlinker there with extended licence for a year. I haven't found it to be intuitive or useful compared to my old ids setup that continues to give faithful service. Well until 2013 anyway. Forscan will connect to newer fords for basics fault reading etc.
Forscan used to automatically insert incodes but they no longer support that. And I couldn't figure out how to do a software update either.
Ironically there's newbies that seem to have no prior experience in diagnostics and they can do everything with Forscan,whereas I'm reasonably handy but so far nada, it boggles me.
Perhaps I'm a clever thick f***r? :lol:
07 350 170ps
Ids map here
loot
Postby icebyte-78 » Sun Sep 15, 2024 7:28 pm
I've installed my "new" steering wheel today, leather instead of the cheap plastic one...
After i installed 180 degrees off the 1st time, 2nd time i noticed the buttons on the steering wheel were a bit different, so no volume ontrols and such... :oops:
So i've taken the airbag of 3 times in total, and swapped over the buttons, and all seems to be working.
Just when i wanted to activate the cruise control on the new steering wheel i found out my Surface laptops battery was dead :| So that'll be for another day.
2017 black 2.0 Ecoblue, high roof, modified fo wheelchair transport
icebyte-78
Postby t0m541 » Wed Dec 18, 2024 5:35 pm
Fitted new handbrake cables whilst the weather is favourable, parking on slopes was starting to be a lottery on whether the van would still be in the same spot when I returned.
I freed off the calipers and fitted new discs and pads when I bought the van 6 months ago, the cables looked ropey but made the effort.
I bought the new ones a while back but lacked the enthusiasm and weather to get them fitted since.
As it turned out, when I removed the old ones, someone had fitted 2 passenger side cables, so the drivers side one was short and was kinked to fit, hence the not very great holding power.
But all sorted, 2 clicks on the lever and the fat old girl stays put.
t0m541
Postby mompracen_bs » Wed Feb 26, 2025 12:25 pm
TC engine 2.0 year 2016, upgrade this winter:
Rim 15">16" (the maximum allowed in Italy for work vehicles)
Front brake disc 288mm>308mm (change only carrier caliper, OEM caliper)
new pads front+rear
Front sway bar 24x?? > 27.0x5.1mm/24.9x4.7mm " FSB double-diameter"
mompracen_bs
Postby TheCake » Mon Mar 10, 2025 10:23 pm
epoxied my broken driver door lock barrel to the door after my van was broken into last night, luckily nothing was stolen.
is that rust spot new?
2010 mk7 t260 85 p.o.s. FWD, SWB
TheCake
Return to Transit Custom
