Problems with 2.5di timing belt change
Postby Ransettimies » Thu Aug 14, 2025 6:50 pm
Hi
I dont know what i do wrong. I have locked alö three spots with drill bits. First two times i got automatic tensioner right, dot at 9 a clock. Still flywheel was missed a tooth. Now i dont even get tensioner right. I start with allen key hole 9 a clock but when i turn tensioner, dot is allways at 12 a clock.
Ive tried slacked belt and tighten it. Allways same problem. Tried even the old tensioner and it does same. Tried whole thing injection pump sprocket bolts loosen and not loosen.
What should i try next?
Ransettimies
Re: Problems with 2.5di timing belt change
Postby Ransettimies » Sat Aug 16, 2025 7:34 am
Problem solved.
Ransettimies
Postby dumper » Sat Aug 16, 2025 7:39 am
There are two holes in the flywheel a deep one that is correct and shallow one that’s not has been mentioned on here but I’ve never had a pin in it even if pinning up after a belt snap
Postby Ransettimies » Mon Aug 18, 2025 10:11 am
Problem was crappy automatic tensioner. I installed mechanical and all good at first turn.
Ransettimies
Postby dumper » Mon Aug 18, 2025 4:33 pm
Never had a problem with both but prefer the mechanical old style ones
Postby gotgcoalman » Wed Aug 20, 2025 12:08 am
dumper wrote:Never had a problem with both but prefer the mechanical old style ones
+1 on the old style tensioner.
Remember the spring lives with the engine
Too bloody quiet :shock:
gotgcoalman
Postby Ransettimies » Wed Aug 20, 2025 11:20 am
Do you mean automatic tensioner spring or mechanical tensioner spring? I installed mechanical without the spring because i didnt have it.
Ransettimies
Postby gotgcoalman » Wed Aug 20, 2025 12:24 pm
This one
gotgcoalman
Postby gotgcoalman » Wed Aug 20, 2025 5:49 pm
The spring I was on about.
Took a while to mind the pics
gotgcoalman
Postby Ransettimies » Fri Aug 22, 2025 1:08 pm
But what will spring do when both bolts on tensioner are thightened?
Ransettimies
Postby dumper » Fri Aug 22, 2025 2:08 pm
Nothing just used to tension the belt you can do it without a spring set the tension to a 45 degree twist on the longest run of the belt
Postby gotgcoalman » Fri Aug 22, 2025 2:38 pm
dumper wrote:Nothing just used to tension the belt you can do it without a spring set the tension to a 45 degree twist on the longest run of the belt
What he said
It just gives a "ball park" indication of where it needs to be.
gotgcoalman
Postby Ransettimies » Fri Aug 22, 2025 8:03 pm
Good that i was thinking too.
Ransettimies
