Sliding Door Only Unlocks When I Lean Into It
Postby ericjmoran2003 » Sat Aug 30, 2025 2:56 pm
Hey all, seems like this is a common issue on the 2010 MK6, so hopefully somebody can help here. When I unlock my sliding door, I hear the actual sound, but the lock doesn't disengage. If I lean against the door, then it works. I'm assuming this means contact with the plate is bad? Is there an easy way to adjust one of the plates?
ericjmoran2003
Re: Sliding Door Only Unlocks When I Lean Into It
Postby knobby1 » Sat Aug 30, 2025 9:02 pm
ericjmoran2003 wrote:Hey all, seems like this is a common issue on the 2010 MK6, so hopefully somebody can help here. When I unlock my sliding door, I hear the actual sound, but the lock doesn't disengage. If I lean against the door, then it works. I'm assuming this means contact with the plate is bad? Is there an easy way to adjust one of the plates?
Yeah...very common...leaning on the rear of the door unloads the lock mechanism...allowing it to unlatch...Possibly the rollers are worn or misaligned, door dropped a bit, or the mechanism itself is getting tired, they don't last forever. The rollers supporting the door are "adjustable" too.
Postby Airthies » Sat Aug 30, 2025 11:21 pm
Door rollers, striker wear. Contact pins damaged or misaligned.
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby andz327 » Sun Aug 31, 2025 9:25 pm
There's an internal part of the locking mechanism that weard but try the above options first as it's expensive for that lock mechanism
andz327
Postby ericjmoran2003 » Sat Sep 06, 2025 6:43 pm
Is there a way to manually unlock it from the inside? The most annoying thing is that even the interior handle for the sliding door doesn't engage, and when the "leaning" method doesn't work, I'm left just using the remote until somehow it finally unlocks. I'm tempted to just disconnect the lock on that door now
ericjmoran2003
Postby Altransit » Sun Sep 07, 2025 10:24 pm
ericjmoran2003 wrote:Is there a way to manually unlock it from the inside? The most annoying thing is that even the interior handle for the sliding door doesn't engage, and when the "leaning" method doesn't work, I'm left just using the remote until somehow it finally unlocks. I'm tempted to just disconnect the lock on that door now
If it's deadlocked, the lever inside won't unlock it, mine has been doing this for years now, and I'm too lazy to try and fix it, but it never fails to unlock if I lean on the lower rear of the door whilst pressing the remote unlock button.
Postby knobby1 » Mon Sep 08, 2025 12:51 am
Altransit wrote:mine has been doing this for years now, and I'm too lazy to try and fix it, but it never fails to unlock if I lean on the lower rear of the door whilst pressing the remote unlock button.
Likewise for me...mine has been like it since I bought the van in 2014..!
Postby Altransit » Tue Sep 09, 2025 1:08 pm
If mine fails to unlock, because I forgot to press in the lower rear, (or the grandkids did it and didn't press hard enough) you have to re-lock the van and try again, pressing the unlock a second time doesn't do it, for some reason :? :P
Postby knobby1 » Tue Sep 09, 2025 7:44 pm
Yep...same.
Postby ericjmoran2003 » Wed Sep 10, 2025 3:40 am
Thanks all! Good to see I'm not the only one using the low-tech way to do this lol
ericjmoran2003
Postby andz327 » Sun Sep 14, 2025 12:45 am
Needs new mechanism .... there's a part that wears inside the mechanism and the pressing of the door moves the worn part a baw hair ....drove me nuts trying to come up with a fix ....the fix is just replace the fooker but fookin expensive even oot a breakers....but so is fixing the dent in the door skin .....but when its changed its heaven
andz327
Postby dumper » Sun Sep 14, 2025 11:24 am
Had a problem with my mk6 didn’t have to press the door to open from outside always opened from inside cured it by spraying the lock mechanism with wd 40 and working it about
Postby Harvy » Wed Sep 17, 2025 11:35 am
Are the MK6 and MK7 sliding door mechanisms the same? I had a problem with my sliding door not unlocking. I watched this video and did something very similar to what he does and the door works perfectly every time now!
https://youtu.be/hxtsgFoTVCE?si=YqipZf_Y_1yvIsOK
2010 T350 LWB H3 RWD 2.4 115 Full poverty spec! :D
Harvy
Postby ogri » Tue Sep 23, 2025 5:12 pm
mine has done this for years. i just look at it as an anti theft aid, and leave it well alone :D
ogri
