Altransit wrote:Is there an immobiliser module on the back of the pump?
dumper wrote:If it’s a single spade end terminal with the ignition on pull it on and off the should hear it click if it’s the stop solenoid on most of the Bosch solenoid you can unscrew it out the pump and remove the plunger refit it and try starting it but if it starts you will have to stall it
dumper wrote:Did it click when refitting with the ignition on you should be able to or feel it activate
Just had another thought have you bleed the fuel upto the injectors slacken the injector pipes at the injector and spin it over with full throttle and see if it pumps fuel out of them when fuel comes out of a injector tighten the pipe and go through all 4
dumper wrote:If you haven’t done anything with the belt before removing the head and refitting I’d expect it to be ok you could repin it to make sure
Even if the valve is not correct as long as there is clearance it should not affect cold start
It’s possible the injectors are defective it’s also possible the pump is not weak and can’t operate the injectors you could remove a injector and pipe it up to the pump outside the engine and see if it operates but be careful not for it to spray on a ignition source
V184 wrote:Why did you change the head gasket ? i have never heard of them failing , Is it a Bosch pump? if so try filling it with diesel through where the inlet fuel pipe fits, keep turning the engine over by hand as the pump takes quite a lot of fuel !
hetman wrote:V184 wrote:Why did you change the head gasket ? i have never heard of them failing , Is it a Bosch pump? if so try filling it with diesel through where the inlet fuel pipe fits, keep turning the engine over by hand as the pump takes quite a lot of fuel !
Thank you for the tips. The engine has been cranking over and over, for a long time. I bled the fuel inlet pipes at each injector, and there was fuel there, but it appears that the pump is not actually delivering the fuel and fuel pressure that is required. I've had a long-term problem with overheating of this van ever since I bought it, and replacing the head gasket was the last thing I'm trying to stop the overheating, which became worse since I lent the van to a friend for 8 months, after which it started really overheating and spewing coolant out of the reservoir. I never detected coolant in the oil or vice versa, but after removing the head, the gasket showed signs of damage between several cylinders, and I had the head completely rebuilt and planed (the valves were all good). I'm hoping this will solve that problem. The pump is a Bosch unit with the "banana" type intake manifold.
dumper wrote:The plug in the front is for checking the timing without stripping the cover off as you say cover off pin the belt and loosen the 4 bolts that hold the pump gear on they will need to be loose when refitting the belt to set the timing correctly then remove the pipe work on the pump the throttle cable unplug the electrical connections.
There should be a support bracket at the back to remove and the bolts holding the pump on
