Which 5 speed behind a 3 litre V6?
Postby Ron Wieringa » Sat Jan 07, 2006 12:54 am
Hi Guys, can someone out there please suggest which 5 speed would be best behind the 3 litre in my MK1? I believe your late model Capri's had these, can anyone recommend a parts dealer? and what price could I expect to pay? Shipping to New Zealand may be a killer, cost me $1000 (UK 300 pounds) to get a set of Lotus Cortina rims out for my Anglia, Cheers, Ron
If I'm going to hell...I'm going in a Ford!
Ron Wieringa
Postby MrMPuk » Sat Jan 07, 2006 12:56 am
I take it it's the Essex V6 if so all the 5 speeds i've seen have been the 4 speed with overdrive.
Postby FredTransit » Sat Jan 07, 2006 12:42 pm
Yup been there, and was told that the 5 speed with an essex V6 was not possible :cry:
FredTransit
Mk2 Trannyist
Postby madmark » Mon Jan 09, 2006 2:25 am
:shock: no not poss unless you have big money! G type with overdrive only! :)
Postby cad69 » Mon Jan 09, 2006 3:47 am
Somebody mentioned to me that I could fit a toyota crown (I think) overdrive behind the existing box. It is a separate unit. Hot rodders seem to have a lot of info on this type of stuff. I often fnd myself looking for an extra gear on my four speed. Must be a bitch to have a three speed.
Cad.
cad69
Postby MRspivvy » Thu Jan 12, 2006 4:03 pm
It IS possible to fit a 5 speed to an essex. You need the 3.0 engine, type 9 gearbox from a 2.8i capri (but I would rebuild it first as it would be a bit marginal on strength with an essex engine's grunt) and this is the hard bit- you need to find a bellhousing from a 1972-74 ford consul 2.0V4.(has to be from a consul, other V4 applications are different) a few years back a firm called vulcan engineering remanufactured these, so I am sure theres one somewhere.
This bellhousing will fit the essex as the 6 has the same block as the 4 and will mate up to the type 9 5 speed. you would need to mix and match propshafts I think. not too sure on the clutch though. maybe essex cover with 2.8 capri plate?
MRspivvy
Postby bortaf » Fri Jan 13, 2006 12:00 am
Yep 5 speed on essex is difficult, but not impossable in fact i know a man who had 2 of the bellhousings last year but i think they went through a cortina site i frequent, i can ask for you if your interested?
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby bortaf » Fri Jan 13, 2006 12:02 am
oops :roll:
Current fleet
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby baconsdozen » Fri Jan 13, 2006 9:23 am
MRspivvy wrote:It IS possible to fit a 5 speed to an essex. You need the 3.0 engine, type 9 gearbox from a 2.8i capri (but I would rebuild it first as it would be a bit marginal on strength with an essex engine's grunt) and this is the hard bit- you need to find a bellhousing from a 1972-74 ford consul 2.0V4.(has to be from a consul, other V4 applications are different) a few years back a firm called vulcan engineering remanufactured these, so I am sure theres one somewhere.
I know I've read somewhere of this being done to a couple of Corsair V4's but despite turning the office inside out I can't find the article.I'm sure the author said that if he was doing the job again he'd try using a Sierra box but other than that I can't remeber the details.
baconsdozen
Postby bortaf » Fri Jan 13, 2006 6:24 pm
corsiars have a hydrolic clutch which is why you use the consol one :)
or so i was told :D
Current fleet
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby baconsdozen » Fri Jan 13, 2006 7:13 pm
Burton Power list a cast alloy bellhousing to mate a V6 Essex to a Type 9 box.Theres a link to them from my site (http://www.baconsdozen.co.uk/motorhome/transit.htm)
The part number is BH4A
baconsdozen
Postby 24vtranny » Sat Jan 28, 2006 12:40 pm
the bell houseing you need is from a 2.5 v6 consul granada. NOT the v4,and just use the transit type 9 5speed circa 88/90 thats the iron one and it bolts straight in to mk1s and 2s,ive done 2 of them.and the gear stick hole is right to. :D :D
24vtranny
essex gearbox
Postby MRspivvy » Sat Jan 28, 2006 7:32 pm
sorry, my mistake.. you are right :oops:
MRspivvy
Postby bazw » Sat Jan 28, 2006 7:56 pm
burton make 2 bell housings for the essex 1 for the type 9 and 1 for the t5 from a sierra cossy both are 465 squid
350L Series 56 plate
2.4 duratorq 115 ps
A.R. 4.27
bazw
Return to Mk 1 & 2
