Oil Warning light
Oil Warning light
Postby fremsley » Tue Feb 19, 2008 2:44 pm
Hi all,
I've finally got my landliner - Blimey I'd forgotten how different it is to drive a V4! The orange oil light keeps coming on imtermittently - flickering on and off - mostly stays off when idling. Is this an electrical issue (I hope) and can someone advise a totally mechanically challenged individual such as myself how to resolve it?
Simon
fremsley
Re: Oil Warning light
Postby MrMPuk » Tue Feb 19, 2008 2:52 pm
Check the connection on the oil pressure switch.
Postby comet » Thu Feb 21, 2008 12:45 am
is it goin on and off with engine cold and hot
1971 LANDLINER - 2.5DI FITTED NEW BY FORDS IN 2000 - IF YOU WANT A COVER UP ASK THE POLICE THEY ARE THE BEST
comet
Postby fremsley » Thu Feb 21, 2008 10:51 pm
Excuse me ignorance but where is the pressure switch? Anywhere near the filter/dipstick - I can drive 'em, but that's about it! It does seem to flicker on and off when hot or cold - sometimes stays on then drops off and then flickers - revving the engine does make it flicker more.
Also i made the mistake of having it hand washed at some soapy joe's car wash ( o get some of the moldy green off) - now the internal striplights in the back won't come on - any ideas - fuses - wherever they are!
Cheers for all your help so far.
fremsley
Postby FredTransit » Thu Feb 21, 2008 11:42 pm
Can't remember where the oil pressure switch is, but the fuse box is under the dash on the driver's side.
FredTransit
Mk2 Trannyist
Postby fremsley » Fri Feb 22, 2008 10:22 pm
Anybody any idea where I look for the oil pressure switch and check the connection?
fremsley
Postby FredTransit » Sat Feb 23, 2008 2:58 pm
Just looked it up, it's on the block above the oil filter.
FredTransit
Mk2 Trannyist
Postby fremsley » Sat Feb 23, 2008 3:06 pm
Cheers Fred - I'll have a look
Ta
Simon
fremsley
Postby madmark » Sat Feb 23, 2008 4:50 pm
how many miles has the engine done ,it might have a worn crank! :wink:
Postby fremsley » Sun Feb 24, 2008 11:04 pm
Thanks all for the advice. i had a wriggle around with the wires near the oil filter and hey presto - no flickering oil light. As for the rear electrics. i found that there is a cutoff switch under the dash which i must have knocked with my legs - so there all working now. Soon as i get a working camera I'll post some pics - she does have a terrible 70s colour scheme of beige and brown (brush painted)- i would l keep it if it were original, but i believe the original colour was a khaki. she may become a brushed steel machine!
fremsley
Postby FredTransit » Mon Feb 25, 2008 3:09 pm
I love it when a plan comes together! :D
FredTransit
Mk2 Trannyist
Return to Mk 1 & 2
cron
