Wahey!-got it at last!
Postby mantav8 » Thu Mar 20, 2008 8:18 pm
Got home and found this on the drive 8) -And I got a long weekend off,shame! LOL!
mantav8
Cosworth Powered
Cosworth Powered
Re: Wahey!-got it at last!
Postby rover » Thu Mar 20, 2008 9:24 pm
Time to get rid of that red thing surrounding the Transit engine then :lol:
Rover.
rover
Postby mantav8 » Thu Mar 20, 2008 9:31 pm
rover wrote:Time to get rid of that red thing surrounding the Transit engine then :lol:
Rover.
LOL!-red THING it is too!-it's hanging!! :roll:
Still sounds sweet and showing 98k,not bad for an old girl.........
mantav8
Cosworth Powered
Cosworth Powered
Postby Terry » Thu Mar 20, 2008 10:52 pm
Any bits you don't want , put them on a Granada/Scorpio site pretty please.
Frinstance the cosworth plastic covers in the engine bay a quite sought after, and if you are really stuck I can probably find a good home for some stuff (not me mines a 97 2.3 Estate) :lol:
Pallet Puller
Terry
Postby mantav8 » Fri Mar 21, 2008 7:07 pm
Terry wrote:Any bits you don't want , put them on a Granada/Scorpio site pretty please.
No problem!-joined up ther and ordered a w/manual LOL! :wink:
mantav8
Cosworth Powered
Cosworth Powered
Todays progress!
Postby mantav8 » Sat Mar 22, 2008 7:04 pm
After faffing about ringing for cars for the missus(women!) finally made a start on ripping the lump out.......
Easy access,
Going....
Gone!
Started to pull out the engine bay loom,hopefully tomorrow will see it out (if I'm not looking at cars!) :roll: :)
mantav8
Cosworth Powered
Cosworth Powered
Postby transitandy » Sat Mar 22, 2008 7:51 pm
VERY NICE 8) 8)
Postby mantav8 » Sun Mar 23, 2008 6:53 pm
Got the loom out,what a pig!-probably won't need it all but hey!
Also got these,only because I don't know what they are! LOL!-any idea's?
I wondered if the square 'box' was anything to do with the auto' box?
:? :wink:
mantav8
Cosworth Powered
Cosworth Powered
Postby OxtonyxO » Sun Mar 23, 2008 6:57 pm
did you find the two fuses
and the box looks like the egr c**p :idea:
OxtonyxO
Postby Guy88 » Sun Mar 23, 2008 7:02 pm
Te square black thing is the exhaust pressre transducer and tother bit is the canister purge valve
Both are for emissions
As tony says you should have 2 fuses and 1 relay (red)
The 2 pin white plug thats by the servo on the granny is Power in (black) and tacho (green)
Then to make it run its 6 earths and 1 permanent live (plus the starter and ruel pump etc)
You'l find the fuel pump relay connections on one fo the plugs that was up under the dash
The other plugs under the dash are auto box connections
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby mantav8 » Sun Mar 23, 2008 7:13 pm
Cheers guys,I took all the relays including the mount! LOL!-remeber mines going to be auto so anything else I need just shout! :wink:
mantav8
Cosworth Powered
Cosworth Powered
Postby OxtonyxO » Mon Mar 24, 2008 1:53 pm
ive been thinking about the cooling system again :roll:
what you need is a dohc rad then move the expansion tank to the right hand side
this would then match the rad and the 't' piece on the granny bottom hose :idea:
OxtonyxO
Postby mantav8 » Mon Mar 24, 2008 10:59 pm
OxtonyxO wrote:ive been thinking about the cooling system again :roll:
Cheers mate,tbh the plumbing etc don't worry me (been there,done that) if it's easier with a dohc rad then I'll buy a new un'!-got the scorp rad and fan to try first,if it's a pain it goes on Flea-bay,simple! :wink:
I'll be happy when the lumps in and running,owt' else is a doddle!
mantav8
Cosworth Powered
Cosworth Powered
Postby martynx » Tue Mar 25, 2008 9:13 pm
I has a cossie grandad 10 years back , or was it a scorpio ? anyway was sooooooooo smooth & refined ... is that why you classic chappies fit them ????
martynx
Postby mantav8 » Tue Mar 25, 2008 9:18 pm
martynx wrote:I has a cossie grandad 10 years back , or was it a scorpio ? anyway was sooooooooo smooth & refined ... is that why you classic chappies fit them ????
Classic chappie?-me? LOL!
hopefully to make a smooth refined Transit,if there can be such a thing!
mantav8
Cosworth Powered
Cosworth Powered
