The 'Cossybus'-updates!
Re: The 'Cossybus'-updates!
Postby Luke » Mon Apr 07, 2008 9:07 pm
well an engine sitting in place is more than i got done today :lol: well done 8)
also you can have the exclusive Image rank :mrgreen:
Postby transitandy » Mon Apr 07, 2008 9:48 pm
good progress m8y :) 8)
Postby mantav8 » Tue Apr 08, 2008 5:38 pm
Cheers guys-started the wiring today,just the fuel pump relay to sort and should be about there!-would have gone for a start tomorrow but some dope forgot to order a fuel filter! :roll:
Gonna' order a DOHC Rad too as been sussing out the cooling and this the easier option,think I need top and bottom hoses too as there not very clever!-also need a hose adapter for a fan switch as I don't think the DOHC rad has one!
Not a lot to see but some pics :mrgreen: ...............
I'll carry on tomorrow! :wink:
Ooooo,I'm liking the 'Powered by Cosworth'!! :mrgreen:
mantav8
Cosworth Powered
Cosworth Powered
Postby mantav8 » Tue Apr 08, 2008 5:53 pm
Oh!-nearly forgot,which is the in/out fuel pipes on the engine?-difficult to see under the plenum and I forgot! LOL! :roll:
Cheers.
mantav8
Cosworth Powered
Cosworth Powered
Postby custom » Tue Apr 08, 2008 6:01 pm
looks awsome much cleaner than mine
custom
Postby Guy88 » Tue Apr 08, 2008 6:49 pm
front pipe is return
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby mantav8 » Tue Apr 08, 2008 7:15 pm
Guy88 wrote:front pipe is return
Cheers Bud!-fingers crossed!!! :mrgreen:
mantav8
Cosworth Powered
Cosworth Powered
Postby madmark » Tue Apr 08, 2008 7:22 pm
:shock: :shock: this is comeing on a treat! 8) 8)
Postby mantav8 » Wed Apr 09, 2008 6:40 pm
Well,finished off the wiring,good job I saved the relay holder as this made a neat job of it all!
added bonus is that I have the spare relays/fuses for the fan etc! 8)
Oh!-I did I mention, SHE RUNS!! :mrgreen: :mrgreen:
How it ended up..........
With the filter in place,
Started on the exhaust today,had to shorten both d/pipes as they hit the subframe! :roll: got both done and the idea is to use the Di d/pipe to make a 'Y' piece and connect to the original silencers.
BTW,couple of questions for the techies!-I run the f/pump relay directly to earth but the wiring diagram shows it going to pin 22-is this o.k.?also think the ecu needs a vss signal,if this is true,is it the actual signal wire I use,i.e the one feeding the speedo?
Also the diagram shows a connection to the stop light switch,is this needed?-remember I'm auto if it makes any difference! and last but not least does any know what colour wires do what one Transit and Scorpio VSS plug?-still waiting for the diagrams I ordered!-will be finished before I get em' at this rate!! :roll:
Cheers all...............
mantav8
Cosworth Powered
Cosworth Powered
Postby rover » Wed Apr 09, 2008 7:31 pm
This is the neatest conversion I've seen yet :D Fantastic work 8)
I'm gona come n find you when its done, seeing as you must be somewhere fairly local to me :mrgreen:
Rover.
rover
Postby OxtonyxO » Wed Apr 09, 2008 7:51 pm
with the fuel pump to earth it will run constantly, instead of being controlled by the ecu :wink:
normally runs to pressure then stops( when ign on)
then runs again on a signal from cps on trying to start
OxtonyxO
Postby mantav8 » Wed Apr 09, 2008 7:53 pm
OxtonyxO wrote:with the fuel pump to earth it will run constantly, instead of being controlled by the ecu :wink:
So is this bad? LOL!-or will it be o.k.? :mrgreen:
mantav8
Cosworth Powered
Cosworth Powered
Postby mantav8 » Wed Apr 09, 2008 7:54 pm
rover wrote:This is the neatest conversion I've seen yet :D Fantastic work 8)
Rover.
Anytime bud!-Hucknall, just off M1 :wink:
mantav8
Cosworth Powered
Cosworth Powered
Postby Luke » Wed Apr 09, 2008 8:04 pm
great progress and great work 8) 8)
as kev says very neat 8) - are you bringing it to north weald :?:
i think you'll be on the road before mine - i had good progress today but not as good as you :lol:
Postby neo1 » Wed Apr 09, 2008 8:06 pm
Fuel pump will flatten battery quick if ign left on, for any lenth of time, also if in a crash or in the event of fuel leakage system will just pump the tank dry, could be very iffy to be honest.
neo1
