excuse me for
excuse me for
Postby Wolfie » Tue Feb 14, 2006 11:40 am
being thick but how are the front wings held on????
got to the stage where i am going to have to do something about mine.
are they welded on or bolted or what????
also if welded how do the fibreglass ones get put on???
ta very much
signed
El Thicko.
1979 2L pinto camper
Wolfie
Postby MrMPuk » Tue Feb 14, 2006 11:47 am
Dunno if it matters but is it a Mk 1 or 2?
Postby Wolfie » Tue Feb 14, 2006 11:47 am
mk1
Wolfie
Postby FredTransit » Tue Feb 14, 2006 11:49 am
The wings are spot welded on at the factory, they have to be hacked off and new ones welded on. Obviously fibreglass can't be welded, so they are screwed or pop riveted on. How bad are the wings? Can they be saved?
FredTransit
Mk2 Trannyist
Postby MrMPuk » Tue Feb 14, 2006 11:50 am
Plus of course it says in you sig! Doh!
Postby Wolfie » Tue Feb 14, 2006 11:59 am
bottoms are rusting away, headlamp bowls going as well also indictors, got rust streaks and bubbles appearing daily, all at front.
back of wings i think prev owner has done a fill and hope job, after he put the new steps in.
also have "found" a pile of rust sitting inside the wing behind the battery in the tube bit that goes back toward windscreen, but have no holes on the top.
Wolfie
Postby MrTransit » Wed Feb 15, 2006 5:38 pm
I have a mk 1 that needs some work done behind both front wings, Is it possible to remove the original wings without damaging them? as mine arn't at all bad?
I saw in a magazine a mk1 that was restored and the wings were converted to bolt on, and i think they were metal wings too. Sounds like a good idea.
My Transit...1.5 tonnes of pure fun!
MrTransit
Postby Luke » Wed Feb 15, 2006 7:10 pm
MrTransit wrote:Is it possible to remove the original wings without damaging them? as mine arn't at all bad?
yes :D
what you need is a spot weld drill
they look like this!!!
they will remove them leaving no damage to the van and only a 10mm hole in the wing - which can be used for re-attaching with a mig welder!!
Top tool 8)
try baconsdozen - he might sell them!! :D
Postby MrTransit » Wed Feb 15, 2006 9:52 pm
Excellent stuff luke, thanks! :D
MrTransit
Return to Mk 1 & 2
