Re-drilling mk3/4/5 front hubs
Re: Re-drilling mk3/4/5 front hubs
Postby MrMPuk » Wed May 21, 2008 7:22 am
I believe there is a for sale section further down the forum! :roll:
Postby MONSTER 0NE » Wed May 21, 2008 9:50 am
i'd be interested in a set luke
MONSTER 0NE
Postby BONKERS24SEVEN » Sun Aug 17, 2008 12:30 am
I have had six sets of high quality aluminium wheel adapters manufactured for transit to 120mm PCD, this is a very popular stud spacing, BMW and Range Rover 16 17 18 19 and 20 inch alloys are easy come by very cheaply, I picked up a almost new set of Range Rover alloys without tyres for £50, I am keeping a set for myself and am selling the others at cost, £150 per set of 4, six was the minimum order for CNC machining, I'm not doing this for a profit. Get in touch if these are of interest, I can have them couriered by DHL for £11.50
They are for Transits with 5 x 160mm PCD and 12mm studs, should fit Marks 1 to 4, the angle of the wheel nut has been replicated at the area where the transit studs go thru to perfectly centre the wheel, I've been told that you could use two adapters on the rear axle and have the front hubs drilled to suit.
BONKERS24SEVEN
Postby Luke » Sun Aug 17, 2008 5:51 pm
for future reference if you want adapters for the back print off this and take it to a local machine shop and they should be able to give you a price :D
and this is what they look like when made :D
the pcd on the studs varies as to what type of wheel you are fitting - if your unsure of anything PM me or start a new thread and i'll help you out :D
now lets keep this thread to FRONT wheel redrills :wink:
Postby Luke » Thu Aug 21, 2008 11:21 pm
Luke wrote:when i made the 1st set of these i was really only doing it to see if it could be done (i like a challange) but after seeing tonys a good mate of mine is after a pair for his mk5swb - so im gonna do a set for him and while im doing them.............. is there anyone else who wants a set :?:
This is a one off opertunity ive no intention of making any more :!:
if you do want a set you would be able to have them whatever 5 stud PCD you wish sorry no 4 studs :(
the cost is going to be around £80 to £100 the more i get done the cheeper it will be, also you will have to provide some hubs and new studs (available from rally design) - these take a while to make so better getting a spare set of hubs :D
and mk3 is different to mk4/5 so get the correct spares :idea:
remember these are only the fronts :!: you will have to sort the rears out yourself - i can help with a drawing of rear adapters but if you search you'll find the info on here allready :wink:
i am confident that these are safe and up to the job, i would not do them otherwise :!:
so if you do want some PM me :D
I had quite a few people PM me about this and ive not recieved any hubs from you yet :!: - if you still want them doing you need to get them to me quickly - i'll be treating the 4 sets ive got very soon and once there done thats it :!:
if you really need me to hang on get in touch otherwise i'll just do these i have
:D
Postby transitgeoff » Thu Aug 21, 2008 11:24 pm
who you talking to :lol:
transitgeoff
Postby Luke » Thu Aug 21, 2008 11:27 pm
transitgeoff wrote:who you talking to :lol:
not just you :lol:
Postby MONSTER 0NE » Thu Aug 21, 2008 11:56 pm
well you already got mine :D :D
MONSTER 0NE
Postby carnut1100 » Tue Sep 23, 2008 3:58 am
Luke wrote:for future reference if you want adapters for the back print off this and take it to a local machine shop and they should be able to give you a price :D
Is there a way to link a file to a post, or upload an attatchment?
I will do a 3D AutoCAD model of this spacer with various PCDs and if anybody wants to get sets made by CNC guys you just give them a copy of the file and they translate it into machine language automatically and off it goes.
I model up most of my projects now, you can get a much better idea of it in 3D and it links so easily to CNC machining.
1979 Mk2 Truck Project thread here
carnut1100
Postby Luke » Tue Sep 23, 2008 12:12 pm
nice one mate 8) you have PM :D
Postby dachre » Tue Sep 23, 2008 6:03 pm
Hey guys, just been searching the web for off-set hubs, axle beams ect, for a rally car and came across a few web pages and info on these sort of adapters that your making up. Thought you may want to check out the info thats all.
Some of the info on hub adapters was interesting to me.
e.g.
Can you build them in steel?
We choose to build our adapters from billet aluminum. When properly engineered, the adapters are stronger than the hub they bolt onto, so it doesn't make sense to machine much heavier adapters from steel. Our adapters have been used on heavily modified 4x4 trucks, rock crawlers, and full-size trucks, without any problems.
Do the bolt-on wheel adapters increase the load on suspension parts?
The suspension loads are only affected by the centerline of the tire. Billet adapters usually correct offset issues when bolting newer style high offset wheels onto older cars that were designed with low offset wheels. A wheel with a 51mm offset and a 2" adapter is identical to the suspension as a 0mm factory wheel. This loads are the same on the wheel studs, bearings, bushings, because the wheel is in exactly the same location on the car.
Can I use your adapters for racing or rock crawling?
We've been using the billet adapters on our twin turbo Camaro road race car. So far we've torn driveshafts, snapped axles, and broken torque arms, and the adapters have always been perfect. We are great at product testing (i.e. finding the limits of components when they break!). If we can't break it, it won't break.
http://www.performancealloys.com/alloy_ ... aptors.asp
http://www.speedace.info/wheels/wheel_adapters.htm
http://www.europerformance.co.uk/pages/ ... cers.mhtml
http://www.skulte.com/info_pages.php/pages_id/3
dachre
Postby carnut1100 » Wed Sep 24, 2008 4:41 am
Well, here's a pic of the model using the info in the sketch.
I can change it to any PCD as well.
Much more fun doing this sort of stuff than the revisions to ship hull frames and so forth that I do at work all day.... :mrgreen:
carnut1100
Postby RatFighter » Thu Oct 02, 2008 4:48 pm
I read this thread with great interest - and i mite change my wheels sometime in the future as i,ve got some OZ alloys in me garage - originally bought for a trike project i'm doing.
they are off a vitara and pcd is approx 130mm 5 stud.
to save me time trawling throught the thread again - are you saying that it is possible to drill your own front hubs after an acurate measure and using a bench press drill but the rears will have to have adaptor plates made?
:?: :roll: :lol: :lol: :lol: :lol:
ooooopS!!! just found the thread - viewtopic.php?f=18&t=2903
Cheers guys
http://www.AVPCustoms.com
THE FINE LINE BETWEEN CREATIVE GENIUS AND ECCENTRIC INSANITY!
RatFighter
Postby towncruiser » Thu Oct 23, 2008 4:10 pm
any one know where i can get sum of those from
towncruiser
Postby OxtonyxO » Thu Oct 23, 2008 4:30 pm
yeah, Take the drawing to an engineering company and have them made
OxtonyxO
