heater fan blows cold on all settins!
Postby luck8869 » Thu Nov 20, 2008 6:02 pm
hi anyone had this problem, engine gets hot and runs normal temp. removed heater pipes and got a good circulation,or is there something i`m not seeing in the heater box, not sure how the heat is controlled? thanks
luck8869
Re: heater fan blows cold on all settins!
Postby Turbo Tim » Thu Nov 20, 2008 6:08 pm
I had this,turned out to be air lock,if it is cable opperated check they are all working(drivers side footwell )
Turbo Tim
Postby luck8869 » Thu Nov 20, 2008 6:15 pm
Turbo Tim wrote:I had this,turned out to be air lock,if it is cable opperated check they are all working(drivers side footwell )
changed thermostat housing in the summer and just got round to using the heater so could be related but cant find a bleed , how did you get rid of the air lock ? thanks
luck8869
Postby Turbo Tim » Thu Nov 20, 2008 6:29 pm
They should self bleed but the hose that goes to the header tank from the thermostate has a restricter in it which gets blocked so it will not bleed,if you sqeeze the pipe you will feel it ,i cut mine out cleaned and then put back in with a jubile clip round it,it has now done 2 years ok, :)
Turbo Tim
Postby luck8869 » Thu Nov 20, 2008 7:31 pm
Turbo Tim wrote:They should self bleed but the hose that goes to the header tank from the thermostate has a restricter in it which gets blocked so it will not bleed,if you sqeeze the pipe you will feel it ,i cut mine out cleaned and then put back in with a jubile clip round it,it has now done 2 years ok, :)
thanks for that will try tomorrow an let you no the out come, cheers
luck8869
Postby Frag » Fri Nov 21, 2008 2:07 pm
Sounds like you`ve got a cable off heater box,the temperature flap one....
Frag
Ford Technician
Postby luck8869 » Fri Nov 21, 2008 9:41 pm
Frag wrote:Sounds like you`ve got a cable off heater box,the temperature flap one....
cheers will check that :!:
luck8869
Postby luck8869 » Fri Dec 05, 2008 5:52 pm
just got back to problem been using another van but need this sorting can you get to the cables without taking the whole box out and wot does it control, ? got hot water to the matrix but no flow through it, thanks anybody
luck8869
cron
