Mk2 vented disc problem
Postby chrisvmax » Thu Mar 26, 2009 12:35 pm
Hi everyone,
I'm in the process of changing the front brake pads on my Mk2 ambulance. It's based on a transit 160, and it's a twin wheeler.
The problem I have is that I have bought the pads, they fit perfectly but the anti-squeal/rattle whatever-it-is things that sit between the pads and the fixing pins are the wrong size. The guy in the shop seems at a loss.
My van has vented front discs which I assume are thicker than standard discs the anti-squeal things are too narrow and the space that fits over the edge of the disc is too narrow.
The one I need looks a bit like this.....
Does anyone know if they can be purchased separately? Or anyone got any spare ones knocking about?
Any help gratefully received.
Regards,
Chris
chrisvmax
Re: Mk2 vented disc problem
Postby nokites » Thu Mar 26, 2009 5:11 pm
Pop to your Ford dealer they will be able to supply you with all the parts you need
OLD CHINESE PROVERB
Man who works for nothing and women who f****s for nothing ---------ALLWAYS GOT PLENTY TO DO
nokites
Postby redeemer » Thu Mar 26, 2009 8:05 pm
Why don't you use the old ones? :idea:
or check for a mk3 twin wheel brakes if they are the same :idea:
1982 MK2 SWB 2.5 DI 5 SPEED 70PS now with turbo
1982 MK2 LWB PICKUP 2.5 DI 4 SPEED
redeemer
Postby chrisvmax » Fri Mar 27, 2009 9:09 am
I am using the old ones for now, but they aren't looking at their best... a bit rusty you know. They certainly won't last long!
If I get a chance after work today I'll get to the Ford dealer and ask there.
Cheers,
Chris
chrisvmax
Postby chrisvmax » Fri Mar 27, 2009 9:11 am
... mind you in my experience they aren't too good on Mk2 Transits :roll:
Cheers,
Chris
chrisvmax
Postby MinorMatt » Mon Mar 30, 2009 10:37 pm
give me a sec... I might have something
Postby MinorMatt » Mon Mar 30, 2009 10:40 pm
Sorry :( what I have is rather different
Postby bron y aur » Tue Mar 31, 2009 1:44 am
forget ford dealers give BIGGRED a call.
i started with nothing, still have most of it left
bron y aur
Still no luck
Postby chrisvmax » Tue Mar 31, 2009 10:19 am
Hi
I tried Ford... they have nothing listed for the MK3 :roll:
The earliest stuff on their computer is from 1990 :shock:
So.... who is BIGRED and how do I get hold of him.... or is he like the "A" Team and he just turns up and everything OK again.
Cheers,
Chris
chrisvmax
Postby Muttley » Fri Apr 03, 2009 10:16 am
Find him on the member list and pm him :)
Expert burns receiver.
Bodger Extraordinaire!!
Fallen in love/hate with Mk6s
Muttley
Postby chrisvmax » Fri Apr 24, 2009 9:51 am
Hi,
I've had a look for Biggred in the members list and have found Biggredvan, beastie and bus but no biggred :roll:
So I googled him and found this
http://www.biggred.co.uk/
Is this him?
Cheers,
Chris
chrisvmax
Postby Muttley » Fri Apr 24, 2009 7:32 pm
Certainly looks like it :) I thought he must be a member on here :oops:
Muttley
Postby bron y aur » Fri Apr 24, 2009 9:35 pm
Yea thats him Chris.
bron y aur
Postby transitgeoff » Sun Apr 26, 2009 7:57 am
i may have someof these, new in ford packets, with the longer pins as well :D pm me if you still need some :D
transitgeoff
Postby chrisvmax » Tue Apr 28, 2009 3:43 pm
Hi,
I've tried Biggred. He doesn't stock them, but reckons they may be the same as one of the Landrover setups.
So. transitgeoff, yes I still need some of these, with pins would be great if you still have them.
How much with postage?
Cheers,
Chris
chrisvmax
Return to Mk 1 & 2
cron
