2.5 TD No Boost - Wastegate stuck?
Re: 2.5 TD No Boost - Wastegate stuck?
Postby scoobysti » Sun Apr 26, 2009 9:26 pm
trans9 wrote: Turbo whistle can be heard when revving under load. quote
I have been told; if you hear turbo whistle, in any case, it`s broken or assembled wrong :?
Exhaust side of tbo, is craked, when/if it whistle.
:oops:
my impreza sti whistles so did my gtir so does my tranny , its a normal thing to hear
scoobysti
Postby dark legend » Sun Apr 26, 2009 9:31 pm
Guy88 wrote:that pipe goes to the brake servo vaccuum line and is used to operate the EGR, just T's into it :wink:
May affect performance if the ECU is confussed
Ahaa, in which case it has never been connected in the camper and is a red herring! Not the problem then.
The turbo must be working if it's boosting on the gauge though? And if the sensor and hence ECU was seeing that boost and putting in the right fuel but the air wasn't getting to the engine for some reason then i'd see a sh!t load of black smoke would I not?
The flexible silicone hose at the inlet was definately inflating when the engine revved up.
I'm starting to suspect this slipped belt scenario more now, but would a whole tooth not bring up the fault light? The ECU has a crank sensor and a sensor in the pump so if they were misaligned would the EPIC not see it?
dark legend
Postby Guy88 » Sun Apr 26, 2009 9:33 pm
up to 4* its OK any more you get timing error code and limp home
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby redeemer » Sun Apr 26, 2009 9:44 pm
Maybe Camshaaft only slipped. But pump and crank kept in phase :idea:
Happened to me. But on an older di, no ecu's stuff.
1982 MK2 SWB 2.5 DI 5 SPEED 70PS now with turbo
1982 MK2 LWB PICKUP 2.5 DI 4 SPEED
redeemer
Postby gardener68 » Mon Apr 27, 2009 7:58 pm
dark legend wrote: the engine note suddenly changed (best way to describe it is probably it sounded more diesely)
im familiar with that senario :roll:
sounds like something has come off or is splitting under pressure..
the engine note changing and power dropping is normally red light territory :?
gardener68
Postby dark legend » Mon Apr 27, 2009 9:34 pm
I've checked all the boost hoses and they look fine, if it was bleeding off that much boost would it not register on the gauge?
Like you say, still can't understand the red light of death not coming on.
dark legend
Postby gardener68 » Mon Apr 27, 2009 10:27 pm
maybe a blockage of some type then :?:
did you use the turbo exhaust system that came with the engine
my old non turbo mk3 used to lose power and make a louder than normal diesel noise when the fuel filter unions came loose and let air in.
you could try checking that out out and re bleeding the injectors.
hopefully somethings just worked loose.
good luck
gardener68
Postby alanwh » Mon Apr 27, 2009 10:30 pm
Think it's got me this one :?
If it's showing .8 Bar at the guage then the manifold is pressurising and there's enough exhaust gas to drive the compressor so it can't all be escaping :roll:
Clutching at straws only things I can think of is that either a valve isn't closing properly or the manifold gasket is leaking and the EPIC is increasing the boost to compensate, the cam timing has slipped or most of the boost is escaping through the egr back to the exhaust manifold. (where are you measuring boost from?)
Hope you sort it soon anyhow mate :)
alanwh
Postby dark legend » Mon Apr 27, 2009 11:10 pm
Measuring boost at the takeoff point just after the EGR flap. Same place the EPIC is measuring it.
Did notice the insides of EGR and metal boost pipe were gunged up with 'coal' so worth a clean of all that side of things I reckon, but can't see that being the problem.
If the EPIC boost sensor was kaput it would exhibit these symptoms I reckon, I know it thinks it's working because it faults if you unplug it, but it may not be giving the right signal?
Check the timing first though, i'll do the new cambelt at the same time.
dark legend
Postby trans9 » Tue Apr 28, 2009 9:19 pm
:oops:
Mine does not, no Tranny, no Volvo, and never heard decent whistle other than broken TBO. (Seen few opened TBO´s) it´s running YES but it is craked OR changeing profile of the "box" :shock:
And yes, there have been prrrrrressures in my vehicles :twisted:
Sory this darn, mis understanded language.
If some body know what I mean and translate this.
If it smokes, it works. But why.... :twisted:
trans9
Postby AndyG » Tue Apr 28, 2009 9:25 pm
Mine whistles :!: :D
Albeit quite faint, but still a whistle :wink:
Has to be said that it was the post '97 ones that did on the smiley :D
Postby trans9 » Tue Apr 28, 2009 9:32 pm
Andyg, you might hear if I whistle here
http://www.youtube.com/watch?v=ENyGj_NQ ... L&index=10
BUT all TBO whistle, A bit, but real whistle, is what means, you dont have to open a window to hear it.... :?
If you have Di tranny :lol:
trans9
Postby redeemer » Tue Apr 28, 2009 9:41 pm
I dont' think that the whistle is a parameter of much importance. it is dependent on the intake filter, air box, silencer , etcc
Even the latest BMW can be heard whistling when accelerating, although its a fine noise.
If he has pressure above atmospheric in the inlet manifold, then most probable the problem comes from the fueling, or timing systems.
I point to the timing, since he hadn't changed it since the swap. Or faulty tensioner!
Has been considering this for a long time: What are the advantages of using timing belt instead of chains? Maybe to give the engine a service (water pump etc) when required to change belt????? :roll:
redeemer
Postby Guy88 » Tue Apr 28, 2009 9:50 pm
the whistling is the wastgate allowing exhaust to bypass the turbine, perfectly normal to hear some :D
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby trans9 » Tue Apr 28, 2009 9:55 pm
Guy88 wrote:the whistling is the wastgate allowing exhaust to bypass the turbine, perfectly normal to hear some :D
Noup. :( Lower pressure whistling is not accept, it is f***ed, if it whistle from start to stop, and I mean lower rews to higer rews, when accselerated.
:x
:oops:
trans9
cron
