It's tricky - you have to get the timing just right. If you trigger it in one direction, it is immediately cancelled by going in the other direction, so you can do it.belly wrote:Can you still thank left right left with the indies if they do that ?
Backbone of Britain wrote:I know you can switch this off on the Focus in the dash menu, can you not do it like that on the Transit.
Scotty86 wrote:Backbone of Britain wrote:I know you can switch this off on the Focus in the dash menu, can you not do it like that on the Transit.
no
I guessed it would be that or not at all - can anyone look it up? I will ask when the van goes in for its first service. If I felt strongly enough, I suppose it would be possible to eject the relevant contact pins from the stalk connector to disable the feature, or even to parallel them with the main contacts so that it worked the same way as the Mk5.jacko1611 wrote:think u can switch it off in the parameter settings using ids.
WINDSCREENGUY wrote:can you add this feature to a mk6? is it just the relay?
