Mk7 'lane change' indicators
Postby Vee4 » Sat May 29, 2010 12:40 pm
I'm not sure if this has been raised before but I couldn't find any references ...
Is it possible to turn off the 'lane change' indicator switching, i.e. where the indicators flash three times if you push the stalk without latching it? I could easily live without it (viewtopic.php?p=553854#p553854) and it is a nuisance if triggered accidentally, e.g. when operating the dip switch.
'69 Mk1 V4 :) >> '76 Mk1 V4 :) >> '84 Mk2 OHC :wink: >> '97 Mk5 Banana :D >> '09 Mk7 TDCi 8)
The van in front is a Transit. It might be my Mk7 - follow the trail of rusty water: Diary of an Ordinary Van
Vee4
Re: Mk7 'lane change' indicators
Postby belly » Sat May 29, 2010 12:42 pm
sorry i don't know the answer :? but can you still thank left right left with the indies if they do that ?
belly
Kaiser Chief
Postby Scotty86 » Sat May 29, 2010 12:51 pm
Don't think you can, you would have to ask fords.
You have the option on the new connect to either have it going off the once or three times but this feature is not on either of my mk7s ;)
2017 Transit Custom SWB RSV
Scotty86
GLX Posse
Postby Vee4 » Sat May 29, 2010 1:23 pm
belly wrote:Can you still thank left right left with the indies if they do that ?
It's tricky - you have to get the timing just right. If you trigger it in one direction, it is immediately cancelled by going in the other direction, so you can do it.
Vee4
Postby ake » Sat May 29, 2010 1:35 pm
I actually quite like the 3 flash feature, and I can still do left right left :wink:
Postby Backbone of Britain » Sat May 29, 2010 1:40 pm
I know you can switch this off on the Focus in the dash menu, can you not do it like that on the Transit.
2006 Mk6 115 T350 LWB Highroof
2008 Mk7 115 T350 LX LWB Highroof
Backbone of Britain
Postby Scotty86 » Sat May 29, 2010 1:48 pm
Backbone of Britain wrote:I know you can switch this off on the Focus in the dash menu, can you not do it like that on the Transit.
no
Scotty86
GLX Posse
Postby WINDSCREENGUY » Sat May 29, 2010 2:03 pm
can you add this feature to a mk6? is it just the relay?
formally grey van man.
WINDSCREENGUY
previously grey van man
Postby Backbone of Britain » Sat May 29, 2010 2:05 pm
no
Thanks Scotty
Backbone of Britain
Postby MrMPuk » Sat May 29, 2010 2:13 pm
I've got this on my Caddy and hate it yet find myself trying to do it when I get back in the Mk6.
Postby jacko1611 » Sat May 29, 2010 2:37 pm
think u can switch it off in the parameter settings using ids.
not another E G F*****G R!
jacko1611
Ford Technician
Postby dwright2104 » Sat May 29, 2010 2:55 pm
Its great in my focus i use it all the time,
n for saying thankyou left right left right, you can still do it, you just have to do an even number, not left right left right left or it stays on 3 times lol
dwright2104
Postby Vee4 » Sat May 29, 2010 3:17 pm
jacko1611 wrote:think u can switch it off in the parameter settings using ids.
I guessed it would be that or not at all - can anyone look it up? I will ask when the van goes in for its first service. If I felt strongly enough, I suppose it would be possible to eject the relevant contact pins from the stalk connector to disable the feature, or even to parallel them with the main contacts so that it worked the same way as the Mk5.
Vee4
Postby uksoftware » Sat May 29, 2010 3:20 pm
There wont be different contact pins, it`s controlled by the ECU. Basically if you held the stalk just enough to trigger the 3 flashes, but kept it held here, the indicators would stay flashing. The latching bit on the stalk just keeps it held in place until either you or the wheel cancels it.
I love the feature, my car has it too. It did take some getting used to, but it`s great now.
uksoftware
Postby ake » Sat May 29, 2010 3:55 pm
WINDSCREENGUY wrote:can you add this feature to a mk6? is it just the relay?
no cos there is no relay on a Mk7, its the BCM that does it
Users browsing this forum: Google [Bot], metalworker0, Mickey_London
