all dash lights out
instrument illumination
Postby mani666 » Thu Jun 17, 2010 5:25 pm
Hi i cant get the instrument illumination on my transit the fuses are ok and so are the bulbs is there anything else that could have caused the problem its a 2.0 td 2002. thanks
mani666
Re: instrument illumination
Postby ripbuster » Thu Jun 17, 2010 6:12 pm
Have you an illumination slide/switch? :P
ripbuster
Postby mani666 » Thu Jun 17, 2010 11:27 pm
hi not that i know of where would it be ? My vans a 2002 mk6
mani666
all dash lights out
Postby mani666 » Fri Jun 18, 2010 12:27 pm
Hi could somebody please tell me what is wrong with my dash lights not all of them work the heater switches dont light up, and neither does the speedo. My indicators work fuel light works and airbag etc etc but the speedo isnt lit up which is a bit of a twat when your driving at night. This all started when i wired a new stereo in could that be the cause??? cant see why when its a seperate loom
mani666
Re: all dash lights out
Postby Timbo » Fri Jun 18, 2010 12:55 pm
The stereo gets a feed for its dial lights from the side light circuit so it sounds like you have shorted it out and it has blown a fuse.
Don't know what van you have but disconnect the stereo and check the fuse for "sidelights" or "instrument illumination".
Timbo
Postby mani666 » Fri Jun 18, 2010 4:15 pm
ive checked both fuses they are ok when it first happened the side lights werent working either they are now though,. The van is a mk6 2.0 fwd swb
mani666
Postby angeleye » Fri Jun 18, 2010 6:03 pm
which fuses are you checking,you need to check passenger fuse box....fuses f47,f56,f73,as they could all have a bearing on problem,f73 is most probable
angeleye
Postby ake » Sun Jun 20, 2010 8:59 pm
Two threads merged :wink:
Postby mani666 » Mon Jun 21, 2010 7:11 pm
Hi i dont have f73 fuse !!! :!: my handbook shows the fuses for the passenger fuse box the fuses i should check are 208 209 201 and there all fine
mani666
Postby ake » Mon Jun 21, 2010 8:57 pm
Best bet is to check every fuse
