mk1 engine change
mk1 engine change
Postby shug58 » Fri Sep 03, 2010 4:35 pm
Have got the old low mileage ambulance running and more or less converted to basic camper. iTS A 3LTR v6 and I'm currently eyeing up a '99 2.5 di banana engine and mt75 box with a view to a transplant. The V6 is fine (15k ! ) and starts and runs great but the mpg...Also, it being a camper I'm planning a few long trips and need to be able to cruise at reasonable motorway speeds.
Anyone out there any experience regarding any compatability issues I may face and/ or the general feasability of this notion.
Also, anybody wanna buy the nations lowest mileage V6 engine and 4 sp. manual box with all ancilliaries?
shug58
Re: mk1 engine change
Postby dumper » Sun Sep 05, 2010 9:30 am
Hi if your mk 1 has the diesel front on it eg the bull nose front you will be ok if not you will need to cut off the front xmember and fit all the diesel front end . xmember bonnet .grill bumper . when themt75 box first came out there was a lot of vans in scrap yards with the transmission tunnel cut out so you may have modify this as well if you can weld it con be done . When I fitted a 2l pinto in to a v4 mk1 I had to do this to the front. as I used the same 4 speed box tunnel was ok. At that time all I did put the engine and box in the van hang it off the Crain and modify the engine mounting I got from a scrap yard .that was twenty years ago and parts for mk1 and 2 vans where plentiful
Postby Leeday » Mon Sep 06, 2010 4:48 pm
shug58 wrote:Have got the old low mileage ambulance running and more or less converted to basic camper. iTS A 3LTR v6 and I'm currently eyeing up a '99 2.5 di banana engine and mt75 box with a view to a transplant. The V6 is fine (15k ! ) and starts and runs great but the mpg...Also, it being a camper I'm planning a few long trips and need to be able to cruise at reasonable motorway speeds.
Hi.. where abouts are you and how much £££`s do you want for the nations lowest mileage V6 engine and 4 sp. manual box with all ancilliaries :D
1989 Mk3 swb, 3.0 V6 Essex, 5 Speed Manual: http://fordtransit.org/forum/viewtopic. ... 3&t=142054
2005 Mk6 2.0 Duratorq 100 T350 MWB Semi High
Leeday
Postby Ollie » Mon Sep 06, 2010 5:42 pm
If you've got a good V6 you'd be one of the few who want to take it out for a DI!!! Why not just gas convert the V6?, easy and simple and prob cheaper and then you'll have cheap running as well as lots of power!!!!
Ollie
Ollie
Postby Leeday » Wed Sep 08, 2010 4:02 pm
Hello :?:
Leeday
Postby Leeday » Thu Sep 09, 2010 10:20 pm
:?: :!: :?: :!: :?: .....Hello :roll:
Leeday
Postby MrMPuk » Thu Sep 09, 2010 10:26 pm
They've not been here since Sunday, try sending a PM.
Postby Leeday » Thu Sep 09, 2010 10:44 pm
MrMPuk wrote:They've not been here since Sunday, try sending a PM.
Cheers MrMPuk :D
Keep forgetting you receive an e-mail when you have a PM :roll:
It is done... Ta
Leeday
