1st Campervan
1st Campervan
Postby solarman » Wed Sep 22, 2010 7:57 pm
This is the Campervan i bought v reg,190 2.5 diesel non turbo,it's a part finished project,was already ply lined with grey carpet,interior lights,skylight vent,windows,
electric 240 volt sockets and EHU fitted,two seat benches,new clutch,new tyres,steel keguards fitted,got a spare bonnet and oven with it,i paid 1380 and it had 2 monthbs tax and 6 months mot,but thbe mileage was a tad high at 183000. well i don't know how to put an image up on thbis forum lol,pics are on computer,do thbey have to be on photobucket or similar?
Solarman.
solarman
Re: 1st Campervan
Postby solarman » Wed Sep 22, 2010 8:00 pm
At some point i will have to cut in the side to fit a vent for fridge and other devices,any tips or know how on doing these?
Solarman.
solarman
Re: 1st Campervan
Postby darkbluevanman » Wed Sep 22, 2010 8:49 pm
darkbluevanman
Re: 1st Campervan
Postby northernlad » Thu Sep 23, 2010 12:31 am
Checkout item:
http://cgi.ebay.co.uk/ELECTROLUX-DOMETI ... 3a5c0e6ad1
For Good Fridge vents, easy to cut hole with a Jigsaw, make sure you mask off around the area you are cutting and also rust proof the cut edge once cut.
Fixing the fridge vents with Sikaflex is better than screwing them onto the body as it creates a good water tight seal and superior adhesion. Plus no screws to rust away.!!
northernlad
Re: 1st Campervan
Postby whitemice » Thu Sep 23, 2010 1:11 am
Hardly worth external venting fridges in this country so long as you obviously vent flue gases you can use inner venting for free air circulation, plus the fridge does not end up completely rusty and filthy.
Another way is to take lower external air below floor at rear of fridge and vent internally at top.
Use non hardening white caravan bedding sealant for sealing flue @£3-4 at caravan dealers.
https://www.youtube.com/watch?v=jIaGWURONRU
'' VOTE Kim Jong Unwell.
Mike writ '' a vote for lABOUR is a vote for islam and a conservative vote is a vote for islam and a vote for liberal is a vote for islam. ''
DBVM ''a vote for UKIP is a vote for islam''
whitemice
Location: normalised heavily chemtrailed cretinous individual just like you
Re: 1st Campervan
Postby northernlad » Thu Sep 23, 2010 1:28 am
I would disagree with Whitemice's opinion, you will find the NCC reccomend venting the fridge as do the largest manufacturers Dometic / Electrolux, only the Waeco compressor fridges do not need venting. In fact we have tried internal venting methods on several vans and ended up replacing fridges which have overheated and failed prematurely.
northernlad
Re: 1st Campervan
Postby whitemice » Thu Sep 23, 2010 1:48 am
This Electrolux RM2200 has only been in this motor 19 years and is still mint, it uses an underfloor external intake from within the ally panel betwixt fibreglass and chassis and vents internally with external flue.
There are motorhome converters that use no external air venting in many an autosleeper.
whitemice
Re: 1st Campervan
Postby solarman » Thu Sep 23, 2010 1:52 pm
well to make sure it complies with regulations or please VOSA when i do this fitting what is the reccomended option? Don't really want to cut too many holes and only want to do this job once.Does anyone know how i can upload pics from my pc on here,thanks,
Solarmnan
solarman
Re: 1st Campervan
Postby Deb » Thu Sep 23, 2010 2:04 pm
First upload your photo to http://photobucket.com or one of many similar photo storage websites, you will have to register an account. Resize your photo(s) to about 600px wide before uploading. (some photo storage websites will give you the option to resize when uploading.) When you've uploaded your photo you will see three or four bits of code that you can copy, you want the one for 'Bulletin boards/forums'. Copy the code and paste into your post.
Debbie
ImageOur budget occasional camper project - viewtopic.php?f=58&t=50286
Deb
Re: 1st Campervan
Postby whitemice » Thu Sep 23, 2010 7:15 pm
One thing, if you do go the unnecessary full-metal-jacket side vents route, considering the cost of new fridgefreezers it would be worth considering the extra cost for the type of covers that can be closed off when not in use as the fridge rear will get filthy and rusted with ordinary types.
However even these 'winter vents' are pretty limited in motorhomes, it is best to run the fridge on 12v most of the time to keep the coolant in circulation which prevents airlocks and this would require you opening the vents everytime you drive.
whitemice
Re: 1st Campervan
Postby solarman » Sun Oct 10, 2010 6:34 pm
solarman wrote:This is the Campervan i bought v reg,190 2.5 diesel non turbo,it's a part finished project,was already ply lined with grey carpet,interior lights,skylight vent,windows,
Solarman.
Finally i've added some pics of the campervan,i think it's a MK 5 ...
[url]Image[/url]
inside lined
[url]Image
[/url]
spot lights fitted
[url]Image[/url]
side windows fitted
[url]Image
Image[/url]
electric sockets for hookup
[url]Image[/url]
bulkhead storage shelf
[url]Image[/url]
engine
[url]Image
Image[/url]
Solarman
solarman
Re: 1st Campervan
Postby solarman » Sun Oct 10, 2010 7:44 pm
Still waiting for a fridge before i can fit everything in.I have a cooker and sink unit still in an old trailer tent whbich i hbave to dismantle,but i got this zig unit which i repaired...
[url]Image[/url]
and here's some solar equipment and inverter to be fitted in later...
80 watt panel
[url]Image[/url]
inverter
[url][Image
Image/url]
solar charge controller
[url]Image[/url]
i'm still gathering things to be fitted in at thbe moment but will post more pics as i go along,
Solarman
solarman
Re: 1st Campervan
Postby solarman » Sun Oct 10, 2010 7:46 pm
Would like some sort of heater,can anyone recommend a suitable economical type to fit?
Solarman.
solarman
Re: 1st Campervan
Postby dachre » Sun Oct 10, 2010 8:33 pm
I use bottled gas in my campervan for the fridge, cooker, grill, water heater. ect.. so it made sense to fit a gas heater as well. The type that I bought was a Propex Heater.
dachre
