Weeping injector....
Postby transitdude » Mon Aug 14, 2006 7:00 pm
Hi all,
Just been inspecting the top of the engine and have noticed this on the nearside injector :
I cleaned it off went for a drive, checked again and it's wet with diesel again. Bummer!
On the previous day I was cracking the injectors in order to bleed the system after a fuel filter change and it has obviously been caused by doing this :(
Does anyone have any suggestions as to what can be done to rectify this situation as I'm guessing it's not a health sign.... the nut is quite tight.
Frank
transitdude
Postby Nighthawk » Mon Aug 14, 2006 8:55 pm
FMC state that the injector pipes should not be undone and re-used, the ends of the new pipe form against the injector when tightened.
you could try undoing the pipe union completely and moving the pipe away from the injector seat and then pressing the pipe back against the injector and then tightening the nut up again.
Failing that, it's a set of injector pipes.
Transit.........Job done
Nighthawk
Postby transitdude » Mon Aug 14, 2006 9:38 pm
Cheers fella, will give it a try.
Frank
transitdude
Postby transitdude » Mon Aug 14, 2006 9:39 pm
I'm hoping that might explain the slight lack of oomph on t'motorway since I've been tinkering.
Frank
transitdude
Postby 100ps_drw_hicube » Mon Aug 14, 2006 9:44 pm
:twisted: :twisted: :twisted: can be a right pain mate retry a few times took us a few attempts at billing at weekend on mine but we got it to seal in the end 8) :lol:
100ps_drw_hicube
Transit Abuser!!
Postby thunderider » Mon Aug 14, 2006 10:57 pm
mine did it for a while,no loss of power tho,then took it in to somewhere else to have the fuel pump reconned got it back ,the leak had mysteriously gone....twas it majic.....
I am the god of hell fire.....
thunderider
Postby WINDSCREENGUY » Tue Aug 15, 2006 9:12 am
ive cracked em off on my 04 tranny and they were fine no leaks i'd do em up really really tight
formally grey van man.
WINDSCREENGUY
previously grey van man
