Why don't you put the METEC 501's in from HID's Direct?.They're a bright white light,(and legal),have a look for them on eBay. FELIXX.Mike Spence wrote:No LED's aren't legal as a retro fit. W5W (501) bulbs fit both parking and number plate.
Felixx wrote:Why don't you put the METEC 501's in from HID's Direct?.They're a bright white light,(and legal),have a look for them on eBay. FELIXX.
davey88 wrote:Cheers guys. So seeing as the reg lights on the rear are non standard would these just be the same 501 bulbs? Am I best getting the 501's with 4 small leds instead of one? Thanks again
Mike Spence wrote:davey88 wrote:Cheers guys. So seeing as the reg lights on the rear are non standard would these just be the same 501 bulbs? Am I best getting the 501's with 4 small leds instead of one? Thanks again
If the lights are non standard then we have no idea of which bulbs will fit them.
RockinRick wrote:I seem to recall when I've had lights like that they used "Festoon" bulbs- the sort like a glass cylinder with a terminal at each end that they often use in interior lights.
I may be wrong!
Rick
Mike Spence wrote:Felixx wrote:Why don't you put the METEC 501's in from HID's Direct?.They're a bright white light,(and legal),have a look for them on eBay. FELIXX.
Because they won't be as bright as these?
Felixx wrote:Mike Spence wrote:Felixx wrote:Why don't you put the METEC 501's in from HID's Direct?.They're a bright white light,(and legal),have a look for them on eBay. FELIXX.
Because they won't be as bright as these?sh*t!!,I bet you can see them from the moon!!............... However,on a more serious note tho,regarding the legality of LED lights,could anyone tell me why HGV trailers are now being made,and, re-fitted with LED lighting systems?.If it's illegal,surely they wouldn't be allowed to fit them,would they?.
FELIXX.
ake wrote:The lights on HGVs are E approved as a whole unit with LEDs. Transit lights are E approved for using filament lamps, not LEDs, thats why its not legal
