these thingsdipstick wrote:Luke, what spacer do you mean, the adapter plate, or something else?....
i know the V6 is longer but so is the Di what we need to know is the Di the same as the V6Guy88 wrote:Luke i never actually thort of that![]()
i think thats what il do.
As for the input shaft i think the V6 is longer. I am going to use the torque converter spacer to hold the spigot bearing same as Oxtony
Luke wrote:i know the V6 is longer but so is the Di what we need to know is the Di the same as the V6Guy88 wrote:Luke i never actually thort of that![]()
As for the input shaft i think the V6 is longer. I am going to use the torque converter spacer to hold the spigot bearing same as Oxtony![]()
excellentdipstick wrote:Luke wrote:i know the V6 is longer but so is the Di what we need to know is the Di the same as the V6Guy88 wrote:Luke i never actually thort of that![]()
Luke, i have just got the two MT75s next to each other, yes the input shaft is the same, they both stick out approx 5mm from the front face of the 'box.
I cannot see any differences between the two boxes at all, on the outside anyway!
I hope this helps in some way.... Cheers
