Whats your MPG ?????
Re: Whats your MPG ?????
Postby Vee4 » Sat Nov 05, 2011 12:43 pm
transitandy wrote:1994 Mk4 van 2.0 Pinto, I'm getting 22 miles to the gallon so not too bad I thought.
I remember the bad old days of 20 mpg in my Pinto-engined Mk2. Now averaging 41mpg in the Ordinary Van (Mk7).
'69 Mk1 V4 :) >> '76 Mk1 V4 :) >> '84 Mk2 OHC :wink: >> '97 Mk5 Banana :D >> '09 Mk7 TDCi 8)
The van in front is a Transit. It might be my Mk7 - follow the trail of rusty water: Diary of an Ordinary Van
Vee4
Postby motorman116 » Wed Nov 09, 2011 3:19 pm
Just worked mine out, on my 57plate long wheel base, high roof 100ps 2.4 tdci 5 speed with 5.11 rear axle, and I am getting 30.22 miles per gallon. Im well happy with that.....
2008 3.2 5 pot diesel Ford Transit GLX Lwb, Hr
motorman116
Postby dee-em » Sat Nov 19, 2011 10:02 pm
11-Plate SWB 260 115PS, current average - 36.2, but i admit to driving like a plonker and thats mainly around town... but on the runs ive done down south i manged an ave. of 49.8 :D.
Bloody Vantastic mate!!
'11 T260 115
Lock and Load - 0845 6805358 / 07783741177
dee-em
Postby transit_tractor » Sun Nov 20, 2011 8:21 pm
2008 t350 mwb 115 rwd fully loaded plus towing 1 tonne caravan 225 miles as 55-60 on motorway plus 30 miles on back roads empty returned 22mpg
transit_tractor
Postby rogerw » Thu Dec 01, 2011 5:04 pm
2.3, 16V does 25mpg and need to replace idle valve - no parts :( . So could be better.
2003, petrol
rogerw
Postby stevo » Mon Dec 12, 2011 11:32 am
Ex rac semi high SWB 300 51 plate. 153K on the clock. Put 15 quid in the other day, did 107 miles. If my calculations are right thats 46 to the gallon.
Formely ibanez2005
2003 100 T260 TDDi swb
stevo
Postby oldosc » Wed Dec 28, 2011 5:03 pm
oldosc
Have 1 year old Hymer Motor home, stacked to the gills with bikes (2) pneumatic catamaran (1) (90 kilos) extra batteries (leisure)
120 litres water (v often)two people ( 470 lbs v often) First trip Rome and back..( after coming from dortmund to cornwall
7776km 1110 litres about 31.8 miles to gallon that is bloody marvellous
My old van a fiat ducato did about 24/25 to the gallon for 148000 miles.
mind you diesel was about 11 p a litre in the baltic states in 1990
oldosc
Postby Trickie Dickie » Wed Jan 18, 2012 8:55 pm
Mk7 T350 140 psi, average speed 8 miles an hour, average millage 25.8 thats with transit and load weighing 3000kls.
Trickie Dickie
Postby boltondigger » Mon Jan 30, 2012 2:33 pm
From a brim to brim fill at ASDA .
did 547 miles
used 73.85 ltr fuel
payed £1.38.7 a litre
+++++33.5 mpg+++++
Is that about right ? most of it motorway miles ,70 to 75mph
58 plate
swb 280 85ps.
next to nowt in the back
small roof bars on
Prob might of improved if i stay below 70?
Had a rusty old 58 plate 85 ps swb.180 thou .most reliable bus ive ever had
12 plate limited 125bhp 260 that got nicked :shock: :shock:
2016 connect poverty spec
boltondigger
Postby Vee4 » Fri Feb 10, 2012 8:41 am
boltondigger wrote:Prob might have improved if I stay below 70?
There's no doubt about that. I have the trip computer on mine and the difference between 60mph and 70mph is quite dramatic (I never go over 70mph, of course). Although it's annoying, the long stretch of the M1 between Jct 13 and Jct 10 where there is a 50mph limit for road 'improvements' has probably saved me a lot of fuel in the last two years.
My van has the 115 TDCi (although as I understand it, the hardware is the same as the 85) plus the 6-speed gearbox, and the most efficient running is with RPM between 1750 and 2000. That is the maximum torque range for the engine.
I'm still averaging around 40mpg, although it's difficult to keep that up in winter conditions!
Vee4
Postby boltondigger » Fri Feb 10, 2012 2:09 pm
dee-em wrote:11-Plate SWB 260 115PS, current average - 36.2, but i admit to driving like a plonker and thats mainly around town... but on the runs ive done down south i manged an ave. of 49.8 :D.
Ive done 3 full tanks in now and still only gettiin 33mpg :roll: :roll:
Driving very conservativley and mainly motorways ,so something is wrong.
boltondigger
Postby ake » Fri Feb 10, 2012 4:50 pm
The roof bars will be knocking the mpg a bit, One of our 350s saw a drop of 50miles to the tank once the roof rack went on
Postby rab501 » Fri Feb 10, 2012 9:42 pm
:twisted: 330 lwb high roof get 25mpg, think its about time lightend the load a little, running just under 4 ton, extra leafs fitted ,pc plod is yet to pull me over : )
rab501
Postby bigjohnthomas » Fri Feb 17, 2012 9:42 am
You have just got drive like a winker my 110 280 run to cov 250 miles 70 ish got 32mpg
Last night 130miles at about 65 ish 38mpg
Flat cap and pipe job :lol:
bigjohnthomas
Postby kmbuilders » Tue Feb 21, 2012 10:44 pm
i have got a transit mk7 56 reg which is really bad on fuel, i put diesel £95;00 in and get 300/310 miles, anyone get any less miles than that ?
kmbuilders
Return to Transit Talk
