a series, need info
Ford A-series 1974 - 1982
a series, need info
Postby tranny van man » Thu Oct 26, 2006 9:06 pm
can any one help? i have decided to keep my a series and restore it but at the moment i have no log book or info on what model it is, the reg number is EJV 651Y it would be much appreciated. :)
tranny van man
Postby Neil » Fri Oct 27, 2006 5:23 pm
check yer kingpins before you start, new ones don t exist
Neil v6
Neil
Postby Luke » Fri Oct 27, 2006 5:24 pm
Neil wrote:check yer kingpins before you start, new ones don t exist
couldn't they be made :?:
Postby WINDSCREENGUY » Fri Oct 27, 2006 5:32 pm
sorry to be dumb what does one look like? i know its a suspension part
formally grey van man.
WINDSCREENGUY
previously grey van man
Postby MrMPuk » Fri Oct 27, 2006 5:34 pm
The round cylinder type thing at the back is the king pin.
Postby WINDSCREENGUY » Fri Oct 27, 2006 5:36 pm
lol i saw that pic on google but didnt have a clue what it was :?
WINDSCREENGUY
Postby MrMPuk » Fri Oct 27, 2006 5:39 pm
There's not really alot to a king pin, the hardest part would be getting the right hardness of metal so that it would wear correctly.
Postby FredTransit » Fri Oct 27, 2006 5:42 pm
Can the kingpins for something else be adapted? Say a D series?
FredTransit
Mk2 Trannyist
Postby MrMPuk » Fri Oct 27, 2006 5:43 pm
Can you get D series king pins then Fred?
Postby FredTransit » Fri Oct 27, 2006 5:45 pm
Never tried, just thinking aloud. What made me think of it was you saying getting the right harndess of metal.
FredTransit
Mk2 Trannyist
Postby Neil » Fri Oct 27, 2006 5:48 pm
d series are different anything can be made,at a price plus you ll need seals its a nightmare
Neil v6
Neil
Re: a series, need info
Postby Granadadriver » Fri Oct 27, 2006 7:30 pm
tranny van man wrote:can any one help? i have decided to keep my a series and restore it but at the moment i have no log book or info on what model it is, the reg number is EJV 651Y it would be much appreciated. :)
According to your previous posts, your model should be a A 0406 (3.5t, 2.4 diesel) For further information and pictures try this site: http://www.fordaseries.co.uk Forum member mexicodan runs this site, and I think possibly he can help you!
Granadadriver
A SERIES
Postby mexicodan » Fri Oct 27, 2006 7:52 pm
HI, LOG BOOKS ARE EASY TO GET WITH SENDING YOUR HARD EARNED 19.00 TO THE DVLA WHO WILL TAKE A FEW WEEKS TO SEND YOU A NEW ONE, (FORM FROM POST OFFICE NEEDS) AS FOR OTHER INFO , LIKE POSTING ABOVE MOST MODEL SHOULD BE ABLE TO BE MADE OUT FROM ENGINE AND WEIGHT PLATE IN NEARSIDE DOOR, THEN JUST CHECK IT AGAINST THE REFERNCES I HAVE ON MY SITE,,
IF YOU NEED PARTS LET ME KNOW I MIGHT BE ABLE TO HELP,
REGARDS DAN
http://WWW.FORDASERIES.CO.UK
mexicodan
Postby ovlov » Fri Oct 27, 2006 8:17 pm
Easiest way to check kingpins is to jack up the wheel so its clear and put a tyre lever under the tyre big lorry type are best with curve at one end put the curve under the tyre and press down so you're trying to lift the tyre you'll be able to see /feel if there's any play
I want to live forever so far so good
ovlov
Postby tranny van man » Sat Oct 28, 2006 9:51 am
thanks lads, i thought it was the big one as ford cargo wheels fit :shock: as for king pins they are sound :o today i am doing a bit of welding to the floor and suprisingley its not that bad :shock: i will start a new post as soon as i get my camara back
tranny van man
Return to Ford A-Series
