MK7 Map Sensor!
MK7 Map Sensor!
Postby squirkane2010 » Sat Jan 21, 2012 2:28 pm
Just thought i'd post these pictures as a indication as to what a map sensor can look like after only 27000 miles!
Van starting hunting yesterday and was down on power so thought i would strip out the sensor and have a look!
The van is only a 60 plate too!
So it may be worth checking yours!
And it was only serviced 7000 miles ago!!!
squirkane2010
Re: MK7 Map Sensor!
Postby Mike » Sat Jan 21, 2012 2:30 pm
It may be worth doing a search ;)
viewtopic.php?f=5&t=96330
Mike
Wind up merchant!
Re: MK7 Map Sensor!
Postby fedup2 » Sat Jan 21, 2012 2:43 pm
As far as im aware,cleaning the map sensor isnt on the list when taking for a service.
Launch x431 owner ;)
fedup2
Re: MK7 Map Sensor!
Postby herman0786 » Sun Jan 22, 2012 3:32 pm
After cleaning ur map sensor did it clear up the problem -van haunting,, thanks
herman0786
Re: MK7 Map Sensor!
Postby V184 » Sun Jan 22, 2012 4:07 pm
herman0786 wrote:After cleaning ur map sensor did it clear up the problem -van haunting,, thanks
didnt on mine !
V184
Re: MK7 Map Sensor!
Postby squirkane2010 » Sun Jan 22, 2012 6:08 pm
Yes it did van now sitting at a steady 800 rpm
Will make it a quarterly check
squirkane2010
Re: MK7 Map Sensor!
Postby herman0786 » Sun Jan 29, 2012 5:16 pm
Is there anything special needed to clean map sensor?,what kind of dirt is on it ?and do you have to be a mechanic to do this, cheers
herman0786
Re: MK7 Map Sensor!
Postby fedup2 » Sun Jan 29, 2012 5:30 pm
herman0786 wrote:Is there anything special needed to clean map sensor?,what kind of dirt is on it ?and do you have to be a mechanic to do this, cheers
petrol,oily crud,no its one torx screw.
fedup2
Re: MK7 Map Sensor!
Postby boltondigger » Sun Jan 29, 2012 5:31 pm
Cleaned mine with a paint brush n petrol.
Was spotless when done didnt make any difference to hunting though,
Had a rusty old 58 plate 85 ps swb.180 thou .most reliable bus ive ever had
12 plate limited 125bhp 260 that got nicked :shock: :shock:
2016 connect poverty spec
boltondigger
Re: MK7 Map Sensor!
Postby Mike » Sun Jan 29, 2012 5:32 pm
Mike Spence wrote:15k miles 140 fwd :o
T25 torx
Mike
Wind up merchant!
Re: MK7 Map Sensor!
Postby herman0786 » Sun Jan 29, 2012 5:33 pm
can anyone tell me were map sensor is located, thanks
herman0786
Re: MK7 Map Sensor!
Postby herman0786 » Sun Jan 29, 2012 5:37 pm
doh!!! if i had just waited another minute i would have seen mikes post, thanks MIKE , i think anyone with hands could actually do that job thanks again
herman0786
Re: MK7 Map Sensor!
Postby nigel green » Sun Jan 29, 2012 6:37 pm
If you require a new map sensor, from fords the complete housing that the map sensor sits in is cheaper by over £10, (includes map sensor) than the sensor on is own, and you get free screw too!!!!
nigel green
Re: MK7 Map Sensor!
Postby psv-hgv-flt » Sun Jan 29, 2012 8:41 pm
clean all mine with thinners and paint brush. that looks like it is down too bad EGR desine.
psv-hgv-flt
Re: MK7 Map Sensor!
Postby squirkane2010 » Sun Jan 29, 2012 10:12 pm
Have cleaned the other 2 vans this week
And found a toothbrush and a toothpick seem to
Work best (just don't use them to clean your teeth afterwards!
squirkane2010
