Van starting hunting yesterday and was down on power so thought i would strip out the sensor and have a look!
The van is only a 60 plate too!
So it may be worth checking yours!
And it was only serviced 7000 miles ago!!!
herman0786 wrote:After cleaning ur map sensor did it clear up the problem -van haunting,, thanks
herman0786 wrote:Is there anything special needed to clean map sensor?,what kind of dirt is on it ?and do you have to be a mechanic to do this, cheers
Mike Spence wrote:15k miles 140 fwd![]()
T25 torx
