Split charge relay question
Postby smartie1984 » Fri Jul 13, 2012 2:47 pm
Hi all,
Been lurking about but have decided to ask a question/opinion.
We are converting our transit into a camper and was wondering if a 30AMP split charge relay would suffice to charge the battery when on the move? haven't got the battery yet, but thinking of 110Ah
It has 2 switched outputs and a permanent output. (also 2 inputs so I can run two thinner wires rather than one thick wire)
I would connect the battery to the switched output so it would only charge when volatage is high enough.
smartie1984
Re: Split charge relay question
Postby KH_Towbars » Fri Jul 13, 2012 5:17 pm
WELCOME TO THE FORUM
Yes 30 amp would be fine,
We use them for the aux charging system for caravans when we fit the towbar, it has 2 switched outputs, 1 for fridge & 1 for battery charging just make sure you earth the relay to the chassis or body :wink:
2016 CUSTOM LIMITED LWB Shadow Black
2010 VW CADDY MAXI 1.6TDi
SOLD VW T5 102 SWB
R.I.P MK6 FWD 2.0TDDI Duratorq, EGR mod, K&N air filter, 16"alloys
KH_Towbars
Postby smartie1984 » Mon Aug 20, 2012 12:59 pm
Hi,
thanks for your reply.
So I think I've sorted out how to wire it up.
As the starter battery is pretty full up with leads I thought I could connect to start motor...would this work?
thanks
smartie1984
Postby Hydraulic Bloke » Mon Aug 20, 2012 1:22 pm
Hi, if you go on flea bay there are a number of auto battery isolaters, got one for mine and is perfect for job, ( I run a couple of 12v motors in the back during work) even has a switch to connect 2nd batt'y in to start engine when 1st is flat
You can go as fast as you want on a push bike
Hydraulic Bloke
Postby MinorMatt » Mon Aug 20, 2012 1:55 pm
That works, but you have missed the input to the relay for switching it!
Postby smartie1984 » Mon Aug 20, 2012 3:28 pm
Hi,
Thanks for the replies.
MinorMatt wrote:That works, but you have missed the input to the relay for switching it!
It's a self switching relay, so I thought that means it will switch to charge battery/turn on fridge when voltage is high enough?
This is what it looks like IIRC
THANKS
smartie1984
Postby KH_Towbars » Mon Aug 20, 2012 7:06 pm
That would be ok but you don't have to go to the extreme of wiring to starter for 30amp draw, a spare terminal in the fuse box should be fine :idea:
SOLD VW T5 102 SWB
KH_Towbars
Postby ake » Wed Aug 22, 2012 8:19 pm
I would advise against making your connection at the starter, either go to the battery directly, or spur from the fuse box
