Upgraded load area light?
Postby gt_addict » Sun Oct 07, 2012 12:27 pm
Hi guys,
I'm looking at upgrading the dim weak little candle like bulb in the back of the van. I just wondered if someone else has done this and what they used
I'm considering using a set of LED DRL's of eBay and hardwiring them up to the existing wiring.
Anyone have any thoughts,opinions or suggestions?
Thanks,
Peter.
gt_addict
Re: Upgraded load area light?
Postby jolly olly » Sun Oct 07, 2012 12:45 pm
I have fitted some LED strip lights in mine theses work great.
Life is not a dress rehearsal
jolly olly
Postby gt_addict » Sun Oct 07, 2012 1:39 pm
Any link to where you got them from or pictures?
gt_addict
Postby jolly olly » Sun Oct 07, 2012 2:09 pm
I got mine from fleabay, will try to remember to get some pics tonight.
jolly olly
Postby Graham Taylor » Sun Oct 07, 2012 2:35 pm
I changed the bulbs to white ones which helped but I also have two additional lights, one over the side door and one above the rear doors that come on when either of these doors open. These are powered from the unused 12v cable in the rear. Makes a big difference.
Graham Taylor
Postby CamsTrans » Sun Oct 07, 2012 2:45 pm
A 3 meter strip of SMDs (surface mounted diodes) with a sticky 3M backing for £7.59 delivered. Just cut it in half, then a bit of cable, bit of solder and shrink wrap and jobs a goodun! :D
I'll be on this one in the next couple of weeks and removing the stock one completely
58 Transit Connect swb LR 75 (Gone)
08 Mk7 Transit Limited swb LR 140 (Gone)
14 Transit Custom Limited swb 125 8)
CamsTrans
Postby gt_addict » Sun Oct 07, 2012 7:55 pm
Cheers for the replies guys.
What's the difference between 5050 smds and 3852?
gt_addict
Postby robbie.cee » Sun Oct 07, 2012 8:14 pm
gt_addict wrote:Cheers for the replies guys.
Just different SPEC.might be colour temperature (in K (kelvin)) or lumen output. Etc etc
Nothing to decide between. Let the price decide!
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby Adam_84 » Sun Oct 07, 2012 10:18 pm
I used 5m of the led tape which has a 3M sticky tape on the back which I stuck to the roof and wired to the existing light nice and bright now.
Adam_84
Postby CamsTrans » Sun Oct 07, 2012 10:20 pm
http://www.prlog.org/10749185-the-diffe ... ights.html
Normally the higher the number the larger the diode or at least it's always been like that in my experience dealing with them :wink:
CamsTrans
Postby gt_addict » Sun Oct 07, 2012 10:28 pm
Adam_84 wrote:I used 5m of the led tape which has a 3M sticky tape on the back which I stuck to the roof and wired to the existing light nice and bright now.
5m? Have you got a pic of it in the dark?
As I was contemplating just a couple of 30cm strips in the centre of the roof either side of the existing light.
gt_addict
Postby paul_h » Sun Oct 07, 2012 10:36 pm
i fancied hard wiring into the wiring loom but decided against it and got some led fog lamps n mounted them (one above sliding door and one near the back door) simply connected them to a wee architrave light switch n mounted this on my bulkhead in the back n simply took a flex into my cig lighter so when i need them i just plug it in n switch the switch.........
hope that makes sense. lol
paul_h
Postby dieselboy1978 » Sun Oct 07, 2012 10:55 pm
I have 3 led camping white led lights fitted to roof, hard wired in and with a switch on the right hand side of the ply lining. Wiredinto an empty fuse point in the fusebox.
Bank account emptied by
DELPHI
dieselboy1978
Postby Adam_84 » Mon Oct 08, 2012 9:42 am
I'll try and get a pic for you mate soon as.
Adam_84
Postby gt_addict » Mon Oct 08, 2012 10:54 am
Adam_84 wrote:I'll try and get a pic for you mate soon as.
Nice one cheers.
gt_addict
cron
