I should monitor the AWD system of a Transit 2.0l produced in 2018.
I can't find dedicated PIDs. Does anyone know if there are any?
It would help me to at least know the front differential oil temperature.
Thank you very much for helping!
VxO wrote:Good evening,
VxO wrote:Near the solenoid there is a bulb that appears to be a sensor (see attached photo).
I need to monitor it via OBDII.
VxO wrote:Unfortunately I can't find the right PID.
Does anyone know if there is a way to deduce this?
Maybe by disconnecting the sensor, and inducing an error, with Forscan I could understand something more.
Thank you.
VxO wrote:I don't know if it's a sensor or a switch.
In any case, if I disconnect it, the fault and unavailability of the AWD system are indicated on the dashboard display. Unfortunately I can't intercept any DTCs using Forscan and Obdlink.
Can anyone tell me how to find the DTC or any sensor reference with Forscan?
Thank you.
