another MK 5 another MOT.
Postby MurrayXmas » Thu Feb 25, 2010 10:56 am
Just got the red fail sheet back and apart from the usual welding list it says that the nearside front position lamp not working when ign is off. It works fine when ign is on though??.......any ideas? Also got an advisory on excessive play in front propshaft carrier rubber....?? Anyway of out to weld in the rain......... :cry: :cry:
WHEN I NOD YOU HIT IT!!
'96 190 lwb banana '99 Lwb Luton Banana
MurrayXmas
Re: another MK 5 another MOT.
Postby dibs » Thu Feb 25, 2010 12:34 pm
Does your lights on buzzer work? Try Fuse 20. If this is blown the headlights will work normally, but no passenger side light with ignition off.
1990 LWB Mk3 twin wheel 190 minibus (My favourite but stolen)
1998 LDV Convoy Ford DI engine but... yuk, yuk, yuk (bought in desperation, sold 2 months later)
1997 SWB Mk5 minibus (Great but small)
2001 LWB Mk5 TD 100ps Minibus (hmm..)
Get me to that gig!
dibs
Postby dibs » Thu Feb 25, 2010 12:54 pm
Sorry, just tried that on my van. Rear light wouldn't work either :( Perhaps just the bulb as only the side lights should be able to be switched on with ignition off :?:
Get me to that gig!
dibs
Postby MurrayXmas » Thu Feb 25, 2010 3:21 pm
Cheers man i'll check the side light bulb!
MurrayXmas
Postby MurrayXmas » Fri Feb 26, 2010 5:16 pm
Na the bulbs fine!! All lights work with ignition on but the nearside head light doesn't work with ignition off!! :evil: Anyway got the drivers step and the top of the wheelarch welded up. Just the passengers step and drivers sill to go.Hope the rain fecks off!!
MurrayXmas
Postby MinorMatt » Fri Feb 26, 2010 5:59 pm
I thought that was a design feature? A parking light
Postby Altransit » Fri Feb 26, 2010 6:06 pm
MurrayXmas wrote:Na the bulbs fine!! All lights work with ignition on but the nearside head light doesn't work with ignition off!!
Neither of the headlights will work with the ignition off :?
When you turn on the ignition, the headlights will come on dimmed, in the sidelight switch position, and bright in the headlight position.
You either have a blown sidelight bulb, the little bulb, or a faulty holder or wire :wink:
Postby dibs » Fri Feb 26, 2010 6:40 pm
On my van, both the side lights come on with the ignition off and the lights turned on. :?
Get me to that gig!
dibs
Postby Altransit » Fri Feb 26, 2010 6:45 pm
dibs wrote:On my van, both the side lights come on with the ignition off and the lights turned on. :?
Yup, thats correct, but when you turn on the ignition, the headlights will come on dimmed, so if you have a faulty sidelight, you won't see it when the ign is on :wink:
Postby dibs » Fri Feb 26, 2010 6:49 pm
True, but MurryXmas says he has checked the bulb. Maybe he should check it again with a new bulb. :)
Get me to that gig!
dibs
Postby Altransit » Fri Feb 26, 2010 6:56 pm
dibs wrote:True, but MurryXmas says he has checked the bulb. Maybe he should check it again with a new bulb. :)
It can't really be anything else but the bulb, or holder, or the wiring to it. Anything else would have another light not working as well :?
Postby MinorMatt » Fri Feb 26, 2010 6:59 pm
does the sidelight work with the ignition on?
Postby MurrayXmas » Fri Feb 26, 2010 7:26 pm
Yeah both side lights work with the ign on. :?
Minor Matt yeah I had considered the parking light feature idea as well. I had a vw polo that if you parked with the indicator on the drivers head light stayed on even with everything else turned off. :roll:
I'm stumped! there's always something on the red sheet that gets ye!!
MurrayXmas
Postby MurrayXmas » Fri Feb 26, 2010 7:28 pm
Hmmm! I'll check the bulb again tomorrow......
MurrayXmas
Postby MurrayXmas » Sat Feb 27, 2010 6:52 pm
Cheers Altransit!!! It was the bulb! All sorted! :oops: :lol:
MurrayXmas
